timing belt issues?
Old 20 Apr 2012, 11:49 am
Default timing belt issues?
Hi all, im new here looked for a long time but finally joined. I have a 2003 PT, just had timing belt replaced, ran for a day had a ticking sound, and just stopped running. I pulled a code for the camshaft sensor replaced it with no results. Any tips on what to do next? Starting to get frustrated!
Old 20 Apr 2012, 03:40 pm
Default Re: timing belt issues?
i would call the place who did the timing belt replacement and have them tow it (at their expense) back to them. seems to me it got screwed up on their end.
Old 20 Apr 2012, 04:54 pm
If the cams are not turning it will give you that code. Like soyomb said let them lick there own calf.
BTW hollo from West Virginia!
Old 20 Apr 2012, 09:10 pm
the cams are turning, unfortunatly a friend did it in his garage.
Old 20 Apr 2012, 09:21 pm
In that case you should appeal to his good side and see if he can help you find out what happened.
Old 20 Apr 2012, 09:24 pm
I'm enlisting the help of everyone i can, I've been reading alot of the different posts on here about everything,and getting alot of good information.
Old 20 Apr 2012, 09:48 pm
Hope you find every thing you need. There is so much info sometimes hard to find what you need. There will be others chim in as time goes on and a solution will show up. Just hang in there.
Old 21 Apr 2012, 01:05 pm
i have fuel at the rail, when i crank it i have spark right away but then it goes away what causes that
Old 21 Apr 2012, 01:17 pm
bad or disconnected ground wire, broken wire by the cam sensor, or bad sensor are what i'd look for before throwing parts at it. do the injectors pulse/does the exhaust pipe smell of raw fuel?
Old 21 Apr 2012, 03:13 pm
i smell fuel at exhaust, all wires appear to be ok
timing issues misa85 Tech & Performance Forum 2 23 Dec 2011 08:01 pm
Timing Belt Issues alioftx Tech & Performance Forum 6 29 Oct 2011 12:06 pm
Timing belt failed, issues with valves? bama7474 Tech & Performance Forum 12 06 May 2011 06:33 am
