Pt cruiser warning lights come on
Old 21 Apr 2012, 02:05 am
Default Pt cruiser warning lights come on
I have a 2006 PT Cruiser and ALL warning lights come sporadically and then go off The car actually died and then picked back up. Anyone hacking similar problem?
Old 21 Apr 2012, 07:14 am
Default Re: Pt cruiser warning lights come on
Start with your battery and all the attached cables. Sounds like you have a short circuit and could be caused by corrosion built up on the cable ends. The battery is under the air filter and most people forget about it because of the old saying "out of sight, out of mind" so they drive until it won't drive anymore.
No "hacking" here, just a simple answer to your problem.
ABS and Traction control warning lights on ieatcake General PT Cruiser Discussions 18 10 May 2014 06:20 am
HELP! '02 Cruiser with no tail lights, then no brake lights. tschauer Tech & Performance Forum 1 16 Sep 2010 05:54 am
Turns Signals, warning bells, and fog lights CaptSi General PT Cruiser Discussions 4 29 Jul 2010 03:32 pm
ABS TRACTION WARNING LIGHTS javaman Tech & Performance Forum 2 12 May 2005 09:34 am
Warning: Undercar lights and a lowered PT CREWZIN Exterior Accessories Forum 8 15 Mar 2004 06:07 pm
