2002 rough idle only when in gear after sometime
  • 1 Post By CREWZIN
Old 21 Apr 2012, 11:18 pm
Default 2002 rough idle only when in gear after sometime
just got done with water pump and timing belt runs great idles great but when in gear and sitting at a stop for 30 sec or so starts to runs rough put it in park or start to drive roughness goes away any idea?
Old 22 Apr 2012, 07:26 am
Default Re: 2002 rough idle only when in gear after sometime
Check that both speeds of the fan are running. Also see if the ruffness goes away when your at idle if the A/C is off.
Old 22 Apr 2012, 07:36 am
Dill's Avatar
X2 for checking the fan, it may not be overheating but when the fan is supposed to kick on the idling does get a little rough.
Old 22 Apr 2012, 12:57 pm
Check your tork strut adjustments.
Old 23 Apr 2012, 10:46 am
I havent gotten the ac rechatged simce the repairs how can i test if both fan speeds are working?
Old 23 Apr 2012, 10:48 am
Adjustement? Hmmm i just unbolted and rebolted them back on. What would be the correct process for adjusting them?
Old 23 Apr 2012, 10:53 am
A lot easier to check if you have A/C. If not, to check both speeds the wiring harness needs to be taken apart and a ground and 12V has to be attached to the connection to the fan to see if both speeds work. Another way is to just hook up an OBDII scanner which can run all kinds of diagnostics and turn the fan on to see if the computer, relays and fan speeds work.
J5BAIL likes this.
Old 23 Apr 2012, 11:04 am
It's in the how too section in the tech section. Engine will vibrate like a small miss in gear at idle. Might be what your feeling.
Rough Idle-Replacing the IAC Idle Air Controller engineerrock Tech & Performance Forum 9 07 Jun 2014 07:24 pm
2005 stalls when idle in gear or ac on no codes snapper455 Tech & Performance Forum 2 27 Mar 2012 05:52 pm
2002 PT Cruiser Rough Idle Kirby1 Tech & Performance Forum 4 13 Jun 2010 10:04 pm
Rough Idle, Rough @60, check engine light NEW Dystroy Tech & Performance Forum 8 12 Jan 2009 09:07 pm
CEL and rough idle greasemonkeyjmj General PT Cruiser Discussions 2 13 Nov 2008 11:55 am
