2006 ignition shroud screw size?
Old 22 Apr 2012, 09:27 pm
Samson's Avatar
Question 2006 ignition shroud screw size?
Hi all,
Can anyone tell me what kind/size are the screws that hold the ignition shroud together? I know the one in the bottom middle is T20 torx, but are the ones on each side the same? The holes are too deep to see. I'm not sure if the hole near the key entry holds the shroud together.
Thank you very much for any help.
Old 22 Apr 2012, 10:37 pm
Samson's Avatar
Default Re: 2006 ignition shroud screw size?
They are both VERY small diameter Phillips head
2006 Ignition switch replacement Samson Tech & Performance Forum 12 19 May 2015 05:00 pm
Need Dash Tweeters Measured Screw to Screw- MoparHemiPower Sound and Security Forum 3 13 Sep 2011 06:41 pm
2006 O2 Sensor Socket Size? bob2006 Tech & Performance Forum 9 18 Nov 2010 03:26 am
Did I screw up? stu88 Tech & Performance Forum 1 31 Jan 2010 03:03 pm
Is Chrysler trying to screw me? biggus127 General PT Cruiser Discussions 8 30 Aug 2007 07:23 am
