Code P0113?
Old 23 Apr 2012, 10:03 pm
Default Code P0113?
I
My daughter has been having problems with her 2004, 2.4 non-turbo Cruiser. It had random misfire with a couple other codes . I changed plugs and wired. Tonight I reset the codes and while I had the air cleaner off I decided to clean the Throttle body. Started it and sprayed some cleaner into the TB, without hooking the IAT up. Now I have a P0113 code, disconnected the negative side of the battery. It's still there. Will I have to have it cleared with a scan tool.
P0113 Intake Air Temperature (IAT) Sensor Circuit (High)
Bobg
Old 23 Apr 2012, 10:06 pm
Default Re: Code P0113?
Bobg (how to you pronounce that?)
It might be one of the codes that will clear itself after so many starts. If your not having any problems now, leave it and see it it clears itself.
Old 24 Apr 2012, 09:25 am
Crewzin,
My last name starts with G, it originated as a typo one should have been capital and it stuck from there on.
I thought I would just leave it and see. This is my daughters car and she's had multiple codes: random misfires, oil light comes on and IAC. From researching on the forum I've changed sparkplugs and wire, cleaned the IAC and she needs an oil change, which I'll do tonight. Hopefully this will clear up most of the codes. She gets off work at 11:00 pm and has to drive 10 miles of curving highway with very little traffic and no cell coverage. So, I need to get it cleared up so I don't have to worry about her getting home.
Bobg
P0113 engine code pthead Tech & Performance Forum 0 29 Mar 2012 03:29 pm
Code Help jennylyn General PT Cruiser Discussions 1 21 Sep 2009 01:57 pm
what is this code medtwo Tech & Performance Forum 2 04 Dec 2008 07:54 am
Code Help! 1lowufo Tech & Performance Forum 1 21 Aug 2004 07:03 pm
