Gurgling noise under hood.
Old 25 Apr 2012, 08:40 pm
Default Gurgling noise under hood.
Hello, I have a 2007 Chrysler PT Cruiser Touring Edition.
Recently, after I have started my car and driving it for 1-2 miles, I start to hear a gurgling noise in the engine, possibly boiling water, so I check my overheater meter, but it is still staying in the middle, not going into the hot zone.
What is my problem? I'd like to fix this before I have to take it to a mechanic.
Old 25 Apr 2012, 09:22 pm
manfred's Avatar
Default Re: Gurgling noise under hood.
First, go look under the hood of your PT and check the coolant level in the reservoir located on the firewall just behind the engine and make sure you see a liquid level between the FULL COLD and FULL HOT lines. Look for the simplest things first.
Old 25 Apr 2012, 09:39 pm
Dill's Avatar
Not to bring in bad news but exhaust gases escaping into the coolant can make that noise too, head gasket if thats the case.
Or a bad radiator cap... The list is endless!
Old 25 Apr 2012, 09:41 pm
manfred's Avatar
So can air bubbles if the coolant was allowed to get too low and air was drawn into the system.
Old 26 Apr 2012, 12:23 am
dunnboy's Avatar
My 03 has done that. it stops after you fill it to the proper fill level and all the air is out of the system. Luckily my reason for losing coolant was a hose clamp just be sure to look for leaks. Good luck
DUNNBOY
03 N/A CRUISER
Old 26 Apr 2012, 10:42 am
Is there a bleeder valve for the air to be let out
Old 26 Apr 2012, 10:46 am
manfred's Avatar
Yep, right under the thermostat housing. Looks just like a brake bleeder fitting. If you put a long hose on it before you open it, any coolant that comes out can be directed into a container, instead of all over the engine.
Old 26 Apr 2012, 02:14 pm
Thumbs up Re: Gurgling noise under hood.
Thanks for the info. I been looking for that valve for a few hours
gurgling noise in top end scottsinfl Welcome New PT Cruiser Members 19 04 Nov 2011 05:24 pm
Howling, gurgling, & popping when I accelerate? Help! ChicagoPT General Turbo Discussions 6 25 May 2011 07:44 pm
Gurgling sound under hood..... KIMS CRUZER Tech & Performance Forum 3 20 Aug 2007 05:57 pm
'Gurgling' Noise ? TripleJackInGA Turbo Performance 9 30 Nov 2003 06:12 pm
Hood Lift Kits/Hood Struts Blaneb Vendors & Buyers Forum 0 25 Nov 2003 10:35 am
