compression psi
Old 27 Apr 2012, 03:23 pm
Default compression psi
what is the compression supposed to be 2003 pt 2.4?
Old 27 Apr 2012, 03:25 pm
Default Re: compression psi
I currently have 30psi on the 2 outside cylinders and 60psi on the inside 2
Old 27 Apr 2012, 03:30 pm
I think is like 120
Old 27 Apr 2012, 03:35 pm
manfred's Avatar
Also, there should be no more than 25% difference between cylinder readings. Put in a squirt of oil to each cylinder on a retest and see if the compression readings go higher. If it does, piston rings are probably worn. If not, leaking valves or a blown head gasket might be at fault.
Mighty Manfred, The Wonder Dog PT Cruiser
Old 27 Apr 2012, 03:36 pm
Did a lot of searching and there doesn't seem to be an exact number but from what I got out of it, all cylinders should be up around 150 to 180 psi.
Old 27 Apr 2012, 03:41 pm
thats kind of what i was thinking, my timing belt was just replaced and quit running a day later, I think the belt must have slipped
Old 27 Apr 2012, 03:46 pm
you're way too low
Old 27 Apr 2012, 10:03 pm
UptownSport's Avatar
It sure did, or they didn't torque cam gears and pin sheared
Compression ptnut Tech & Performance Forum 12 21 Nov 2011 11:40 am
Compression problem 04stocker General PT Cruiser Discussions 4 17 Apr 2011 11:08 am
The no compression engine PTProblems Tech & Performance Forum 2 01 Apr 2011 09:15 pm
engine low on compression LoWandSloW Tech & Performance Forum 7 02 Jul 2007 09:58 am
compression fittings Punch Exterior & Interior Styling 10 11 Nov 2003 10:36 pm
