No fire computer cant read tone ring
Old 28 Apr 2012, 01:23 pm
Default No fire computer cant read tone ring
I have a 2001 cruiser and rebuilt a 2003 engine and put it in the 2001. My problem is according to ask a pt cruiser mechanic that the engine is not firing is due to the computer cant read the 2003 tone ring on the crankshaft. the 2001 crank has a different tone ring. is there any way I can make this engine work in this 2001 cruiser, possibly by changing the PCM to a 2003 or can it be reprogram to read the 2003 tone ring. Please help. I spent over $1000 rebuilding this 2003 motor and seem like i cant use it.
Old 28 Apr 2012, 10:13 pm
TurboDucky's Avatar
Default Re: No fire computer cant read tone ring
Changing everything over to '03 up would be extremely difficult. ECM - Wiring harness - Etc. The older PT's had a 2 plug ECM, the newer has 4 plugs, and they don't interchange.
2005 Dark Slate Gray Convertible - 2.4 Turbo Lite'ish - Automatic.
2001 PT Cruiser - NA - 5 Speed - Exhaust and CAI Mods - It's alive!!!
Old 28 Apr 2012, 10:38 pm
UptownSport's Avatar
'93-'02 computer's won't read your NGC '03 block.
Easiest is use your old '01 head on a older block.
Old 29 Apr 2012, 06:11 am
compdr59's Avatar
You should have done your homework. You may be able to find someone parting and 03 and rewire everything.
Original Owner 135k
Old 29 Apr 2012, 07:01 am
TurboDucky's Avatar
Where are you located? I might be able to hook you up with a reasonably priced engine...
-Gary-
Reverse ring ring turbomangt General PT Cruiser Discussions 12 06 Apr 2007 11:35 am
Bad Ring turbokidd Turbo Performance 2 17 Feb 2007 03:35 pm
High Tone Horn/Mistake need low tone help gonzomania General PT Cruiser Discussions 7 25 Feb 2006 08:34 pm
WTB~4 ga. ring terminals OurPTGT Classifieds: Want To Buy 5 13 Feb 2005 04:24 pm
