Steering wheel locked/key wont turn!
Old 28 Apr 2012, 08:51 pm
Angry Steering wheel locked/key wont turn!
I tried to get in my car last night, and my key won't turn. I've tried jiggling the steering wheel, which usually works, but didn't this time! Tried various methods, (jiggled wheel/key at same time, just key, took key off keyring, pulled out a hair, turned key over, pumped break, etc) Yes, the car is in park, and yes it's the right key. We do not have an owner's manual with the car! It's a 2002 model, if that helps.
Old 28 Apr 2012, 09:07 pm
cannesman's Avatar
Default Re: Steering wheel locked/key wont turn!
Hang in there Amber, I'm sure someone will be along to enlighten you. Myself, IDK why, surprised pulling the hair out didn't help though
It's the wife's PT......but I get to drive it on occasion
2003 Inferno Red GT.........no mods.....stock.
Old 28 Apr 2012, 09:12 pm
Thanks. Yeah, I just want to set it on fire or something. Couldn't have happened at a worse time! and there is no owner's manual, so idk.
Old 28 Apr 2012, 09:16 pm
soft copy of the owner's manuals for all years/models is available in the tech/performance section, one of the first stickies titled "library". As to the keylock, is your car parked on a hill?
Try holding the steering wheel all the way to the right, pull hard, then try the key. If not, pull hard to the left and try again. If you're on a hill, it can cause this issue sometimes. Can you shift into neutral? If so, hold your foot on the brake, shift to neutral, loosen your foot on the brake, see if you can shake the car into moving just a couple of inches, then back into park. See if you can now move the steering wheel to free up the ignition.
Now, if this works and you get it free, the cost of my advice will be one nude photo.....LMAO yust yoking, darned olde farte pervert!!!
Old 28 Apr 2012, 09:19 pm
not on a hill, and it wont shift into anything. stuck in park.
Old 28 Apr 2012, 09:40 pm
Dill's Avatar
Have you tried turning the steering wheel hard back and forth while attempting to get the key in and turned on?
Old 28 Apr 2012, 09:42 pm
Dill, yes I have
Old 28 Apr 2012, 09:47 pm
UptownSport's Avatar
This happened to my bro's car the other day.
Either key/tumbler or both were so worn that it wouldn't turn-
We removed the protective plastic, loosened the T10 (security) screws and somehow got tumbler to turn.
Drove home, put in a JY tumbler, replaced lock mechanism, it's been fine.
Like yours, this didn't come out of the blue.
there's also a small bakelite rod that seems to lock up tumbler, it's ~$25 from Rockauto.
Old 28 Apr 2012, 09:52 pm
How hard is it for a mechanically stupid person to do? And how do i even know if thats what's wrong?
Old 29 Apr 2012, 06:24 am
compdr59's Avatar
May be time to call AAA. If you don't have a membership you can buy one for $48.
Original Owner 135k
HEADLIGHTS WONT TURN ON beanpt Tech & Performance Forum 15 29 Apr 2018 12:01 am
Radio Locked, Turn Ign To Run? vanaste Sound and Security Forum 3 12 Feb 2012 08:04 am
Steering Wheel Locked Up! Spectrum Tech & Performance Forum 4 16 Jun 2011 12:31 am
car wont turn on. fvillota General PT Cruiser Discussions 12 06 Apr 2009 10:56 pm
Brakes failed and steering locked in my cruiser chellabella General PT Cruiser Discussions 5 02 Feb 2008 08:56 pm
