2008 - 2.4 owners
Old 30 Apr 2012, 07:20 pm
Default 2008 - 2.4 owners
Well, I have been having fits but cant imagine its true. Recently plagued with rough idle and misfire issues I bought a Haynes repair manual. Ummm, my EGR valve isnt where they say, I dont see any exhaust connection or tube to the upper intake manifold. Also I cant find the MAP sensor, it also is not where they say it is. So, is the Haynes wrong, or was mine removed? I see a shiny brass plug where the tube to the upper intake should be! Can anybody shed some light on this?
Old 30 Apr 2012, 07:31 pm
Default Re: 2008 - 2.4 owners
Only the first two years had the EGR valve and the tube that ran down the back of the upper manifold. I have 3 manuals, (Haynes 01-03, Haynes 01-09 and Chilton 01-03) and all look they were copied from each other. Doesn't look like that up dated the 01-09 except for changing the title.
Old 30 Apr 2012, 08:55 pm
Aha. It figures. EGR must be on the air box side of the block then maybe buried? I dont see anything leading to it, vacuum lines etc. Really weird
Old 30 Apr 2012, 09:08 pm
TurboDucky's Avatar
If you have a 2008, then you don't have an EGR valve setup.
2005 Dark Slate Gray Convertible - 2.4 Turbo Lite'ish - Automatic.
2001 PT Cruiser - NA - 5 Speed - Exhaust and CAI Mods - It's alive!!!
Old 01 May 2012, 03:53 am
No kidding! No EGR, wow! Those things have been standard items since 1972. Is there no MAP sensor either?
Old 01 May 2012, 06:07 am
TurboDucky's Avatar
Should have a MAP sensor. All the ones I've seen are on the back of the intake, towards the passenger side.
Old 01 May 2012, 06:48 am
MAP sensor, on the back edge of the upper manifold.
Old 02 May 2012, 04:24 am
Ok thanks. After re-gappig the plugs now it seems to idle rougher on colder mornings. Gets better as the car warms up. Fuel mileage has dropped. Plugs were grayish white, all even. It seems to be running lean which would be a fuel or manifold leak.
Old 02 May 2012, 05:41 am
Kawizx9r's Avatar
If you had a manifold leak, you'd hear it for sure (vacuum leak).
Sorry I can't add more to this.
Kawi is a friggin genius!
Old 03 May 2012, 04:26 am
Crewzin I found the MAP sensor. Geez I blind sometimes
PT GT atx owners 05PTGT General Turbo Discussions 31 18 Dec 2011 02:14 am
We are now the owners.. morrises General PT Cruiser Discussions 13 16 May 2008 10:37 am
PT owners skeeter1620 General PT Cruiser Discussions 21 01 Feb 2004 03:38 pm
New owners mamamia General PT Cruiser Discussions 4 02 Mar 2003 11:09 am
Gt Owners only turbomangt General PT Cruiser Discussions 9 06 Feb 2003 09:57 am
