Leak near thermostat
Old 03 May 2012, 12:58 pm
Default Leak near thermostat
I've done a head gasket replacement and have issues with water pump, thermostat, etc... in the past, so there have been several times that I've had to remove the radiator filler neck. In doing that repeatedly, I must have over tightened the two bolts that mount the filler neck to the aluminum flange on the head, and I've stripped the holes out. I'm worried about tapping the aluminum to accept larger bolts. I don't think the tap will go deep enough to thread the new bolts all the way in and if I drill deeper I could cause a head leak, or worse. Has anyone had to do this before? Any advice?
Old 03 May 2012, 01:26 pm
Default Re: Leak near thermostat
Definitely over torking these. Are both holes stripped? The only one to worry with is the one next to the head. It's the only one that can penetrate the water jacket.
Old 03 May 2012, 01:54 pm
fabreezai's Avatar
You can drill them out and use a heli coil kit to re tap them to the stock bolts.
Cheers! 2003 2.4, N/A, Touring, Supercharged, 5 speed. 126k..... Blew up that engine, building another to take the boost! Built a new engine, still working out some issuess.......
Old 03 May 2012, 03:17 pm
dunnboy's Avatar
If you can get a solid hold after taping for the bigger bolt use washers to make up for the gap that you've created by not going very deep
DUNNBOY
03 N/A CRUISER
Old 05 May 2012, 11:13 pm
UptownSport's Avatar
QFT,
Plenty of room, you're at 8mm (5/16") so 10 would be huge.
when a bolt goes into aluminum, put a drop of motor oil etc on it.
Thermostat bad/Error0128 aix Tech & Performance Forum 5 31 Mar 2010 06:42 am
Need thermostat help Styggian Tech & Performance Forum 1 01 Oct 2009 06:53 pm
Thermostat is too big??? jkdrummer Tech & Performance Forum 1 20 Mar 2009 06:02 am
Thermostat or Fan JazzeCouture General PT Cruiser Discussions 1 25 Jan 2009 09:05 am
Thermostat gasket leak? BABYbluePT Tech & Performance Forum 3 03 Jan 2008 03:16 pm
