p0304
Old 05 May 2012, 12:17 am
Default p0304
awhile ago at school i had a miss fire where it shook the car on cylinder 4. changed plugs and wires. today i was driving back from my grandfathers and the check engine light dinged and flashed then went away. checked my code with my scan tool and same p0304. i also have the incorrect coolant in the system right now. tomorrow(saturday) it will be changed over to the green "universal" type. it has dexcool in there. could that be doing the miss? also how can i check that injector that is missing?
Old 05 May 2012, 06:25 am
Default Re: p0304
First, that universal green coolant is NOT the right one to switch to. You want the HOAT orange coolant.
Second, Doesn't the scan tool that you used to check for the code have the program to go through all the different parts of the ignition system to check each one for trouble or is it just the tool for bringing up fault codes? An OBDII scanner can go through all the workings of the car to see what's wrong. Plus, your P0304 cold be a small crack or vacuum leak in the upper manifold and not a bad injector.
P0304 Cleared... duffner Turbo Performance 10 04 Feb 2014 11:26 pm
p0304 code manzanman Turbo Performance 6 04 Jan 2013 05:56 pm
p0304 help needed!!! cvessells78 Tech & Performance Forum 4 10 Mar 2012 12:47 am
P0304 DillAlexanderEF Welcome New PT Cruiser Members 3 08 Dec 2011 02:20 am
P0304 Success elmeyer Tech & Performance Forum 5 21 Jun 2010 09:24 pm
