Timing Belt Broke- Are Values Bent?
Old 07 May 2012, 02:59 pm
Default Timing Belt Broke- Are Values Bent?
Hello:
I have a 2004 PT cruiser limited edition turbo 2.4L and my timing belt broke this morning on the way to work.
The dealership told me that the values might be bent?
I thought this type of engine the values do not bend when the belt breaks.
So, I need help/advice.
Has anyone run across a 2004 PT where the timing belt has broken and the values were bent?
Any help is appreciated.
Old 07 May 2012, 03:22 pm
cruserdad1976's Avatar
Default Re: Timing Belt Broke- Are Values Bent?
This probaly has to be the #1 asked question on this board which is ok thats why its here
so here is your answer
#1 The Engin in a PT cruser is a NON INTERFERANCE engin
#2 That means that when the TB breaks the Valvues CAN NOT hit the pistons
#3 In some VERRY rare events the Valvues CAN hit each other
#4 That may or may not bend a valvue
#5 There is no way to tell Untill AFTER you do the T/B and can run a compression Check
#6 I thnik it has been said that of the hundreds that have broke a T/B under acceleration that only like 2-3 ever bent the Valvues
So to sum it up there is a better than average chance that you are ok
The dealerships are BIG TIME on scarring people inot thinking they need a new head.new engin,new car whatever
When or if you replace the T/B go ahead and replace the water pump the T/B tensioners and id change the serpintine belt you are already there and the cost in minimual
Just my opinion other will chime in but thats how I see your sitution you shopu;d be good to do the T/B and drive away
One more thing the T/B should be between $900-$1200 anything more you are being riped
Old 07 May 2012, 03:42 pm
Thank you so much.
The dealership quoted me $1150.
And they did call back to say the tech has never seen the values bent on this type of engine when the t/b breaks.
So all signs seem to point in the ok arena.
Thanks!!!
Old 07 May 2012, 03:44 pm
Sorry to hear that ..how many miles do you have ?
Old 07 May 2012, 03:56 pm
101,000 miles
Old 07 May 2012, 04:07 pm
WOW..that's low but is about 8 years old
Old 07 May 2012, 04:15 pm
Davey's Avatar
Low? sounds about right to me.
Old 07 May 2012, 04:49 pm
I know is the right miles, but I've seen a lot of people breaking it at 130k miles or more and a few at 80k...My wife's 01 N/A had 125k miles when I replaced it.
Old 07 May 2012, 05:13 pm
^^^^^^X2
Old 08 May 2012, 08:17 am
reevescajr's Avatar
Originally Posted by ilzho View Post
Thank you so much.
Thanks!!!
Thanks for posting this; I had been wondering how much a dealer would charge, and this is about what I guessed. My 2003 turbo only has 65k miles on it, but even though it isn't close to the 90K miles where the owner's manual says to replace the belt, I have been a little conceded about its age.
Bent valves after timing belt bobdole369 Tech & Performance Forum 8 28 Mar 2014 11:49 pm
Important Question Regarding bent Valves/Timing Belt Tommy2Shoes Tech & Performance Forum 19 27 Mar 2014 09:33 am
Possible broke timing belt help please Mabney007 Turbo Performance 4 13 Dec 2011 11:29 am
Timing Belt Broke? scatgo Tech & Performance Forum 10 10 Nov 2009 01:55 am
