Air Box Mod Malfunction
Old 09 May 2012, 09:18 pm
Default Air Box Mod Malfunction
So I got my K&N drop in and decide to shorten the snorkel in the airbox flush to the wall of the box. Cut the snorkel and clipped in back in to the side of the airbox easy peasey. I then put everything back together started my car and my check engine light came on. Wasnt on 30min prior when i got home from work just happened as soon as i got done with the mod. It may have nothing to do with it but just seeing if anyone else has had this problem. I also removed the oil filter hose from both the airbox and the manifold and noticed it was tore down the middle on the manifold end if that means anything. Went to pep boys but the difference in the size of the ends Im going to have to pick one up from the dealer I guess. I dunno maybe its jsut sucking more air than ever and it just cant keep up. Nice power gain, car seems to run fine...........for now
Old 09 May 2012, 09:24 pm
fabreezai's Avatar
Default Re: Air Box Mod Malfunction
"Key dance" and see what code comes up for starters.
Cheers! 2003 2.4, N/A, Touring, Supercharged, 5 speed. 126k..... Blew up that engine, building another to take the boost! Built a new engine, still working out some issuess.......
Old 09 May 2012, 11:06 pm
No guessing about it, you will need to get that hose from the dealer AND get the hose for the other side (make-up air hose) while your there. It will be the same age and condition that the PCV hose is in and probably ready to also fail. They both are subjected to hot oil-born air all the time the engine is running. They will eventually fail on our PTs as well as EVERY other car that has been produced in the last 60 years.
Also, this is important, pick up a PCV valve and the small "make-up air" filter that is contained in the airfilter box, to correctly update the complete PCV sytem! If the hose itself had detererated far enough to split, the PCV will be coated inside even if the ball does pass the rattle test. With the coating inside it could stick at the most inopportune times.
Jerry
Old 10 May 2012, 06:32 am
KEY DANCE? Whats that?
Old 10 May 2012, 07:23 am
mdskinner731's Avatar
cycle the key >> "ON-OFF-ON-OFF-ON" where your odometer is dipslayed will show up with codes. wen finished the screen will say "done"
if it moves and not supposed to... duct tape!!!
if it dont move and is supposed to... WD-40!!!
~* the problem with america is warning labels.... take them off of every thing and eventually the stupid people will die off... *~
Old 10 May 2012, 07:48 am
Dill's Avatar
Worth noting, you will see the word done when you do it correctly. If you do it and see no "done" you need to try again.
Odometer malfunction cmoench Tech & Performance Forum 0 29 Apr 2011 01:09 pm
PCM intermitent malfunction Gtcruiserowner Tech & Performance Forum 3 16 Mar 2010 11:32 am
AC malfunction tezz Stage Turbo Kits 4 27 Apr 2004 02:45 pm
ABS Malfunction? spicy pt General Turbo Discussions 6 26 Apr 2004 05:01 pm
malfunction in fog lights bigdaddy2o General PT Cruiser Discussions 9 09 Apr 2004 03:20 am
