P0456
Old 10 May 2012, 06:20 pm
Default P0456
So I have a leak....Im wondering if its the the oil line that is crakced from the manifold to the airbox(i think it is) or if Im leaking boost. I know its the gas cap so im lost. Ill do a couple recon missions under the hood and let you guys know what happens. Thanks for the help
Old 10 May 2012, 06:36 pm
Default Re: P0456
From Chrysler, Just Answer:
P0456
What this means is the car is detecting a leak in the fuel system. Not a leak of liquid fuel, rather a leak in the airspace or gas fumes section of the fuel system.
This type of failure often turns out to be a bad gas cap. Sometimes there can be a rust spot on the fuel tank or filler neck or another leak elsewhere in the fuel vapor system.
My recommendation is to get a new fuel cap and drive the car. If the leak is fixed, the engine light will go off on its own after a few days.
After a new fuel cap, if the light does not go off on its own after a week of driving the car everyday, you will need an emissions mechanic or smog shop to pressure test the fuel vapor system with a smoke machine to find the leak. Often the smoke machine reveals a split rubber hose somewhere in the evap system or a rusted out fuel filler neck.
Old 10 May 2012, 08:55 pm
Default Re: P0456
So do you think it detetected that split in the oil line, I checked the gas cap and its fine and it doesnt seem that im burning more fuel than i normally do
P0456
Engine Code P0456? AngelLover89 Tech & Performance Forum 1 10 Mar 2011 03:03 pm
Error code P0456 & 0340 RoadTramp113 Tech & Performance Forum 12 21 Feb 2011 08:29 pm
2002 Pt error code P0456 chellee Tech & Performance Forum 2 24 Jul 2008 07:56 am
code p0456 Punch General PT Cruiser Discussions 0 26 Aug 2003 02:10 pm
