p1596 speed control switch always high
Old 13 May 2012, 01:51 pm
Default p1596 speed control switch always high
what those this code mean and how to fix it thank you for input
Old 13 May 2012, 02:18 pm
Default Re: p1596 speed control switch always high
1596 is "speed control switch - always high voltage". That refers to your cruise speed control. It usually comes up as a result of a "clock-spring" failure. It's inside the upper portion of your steering wheel. It is ---NOT---I repeat NOT something that someone that is not familiar with airbag repairs should even think about attempting. The horn, etc. also work off of this "clock-spring". The air bag has to be pulled to change out the "clock-spring" and the air bag is very dangerous to work with!!!
PLEASE take it to a dealer or trusted mechanic to diagnose and/or repair.
If you are a good mechanic and want to attempt this repair, buy a Haynes manual and follow the directions on pages 10-11 10-12 and 10-13. It's got pic's (illustration 16.8) and "everything". I've had my steering wheel (air-bag) off several times with no dire results, but as I said, be careful!!!
Jerry
Old 14 May 2012, 02:42 pm
CAn this problem has to do anyhting with a connection. I have a bad connection that I have to fix behind the fuse box.
Locating Radiator Fan relays High Speed and Low Speed CashReject Tech & Performance Forum 14 06 May 2017 12:12 am
PT 2002 LOW AND HIGH SPEED NOT WORKING sliver Tech & Performance Forum 9 10 May 2012 10:53 pm
A/C High Pressure cut-out Switch myanez Tech & Performance Forum 2 03 Oct 2011 09:59 pm
01 Pt Overheating at high speed only blackcat317 Tech & Performance Forum 4 13 Apr 2010 09:30 am
high speed run : ) 140mph run! Punch Turbo Performance 21 03 Jan 2004 08:22 pm
