Drop in MPG
Old 14 May 2012, 01:55 am
Default Drop in MPG
Here's my dilemma. First, my fog lights would stay on constantly (and I didn't know it was happening) so my battery was drained. Battery was original (2004) so got a new one, not knowing the fog lights was the issue just knew my car wouldn't start and I was 50 miles from home so got a jump. Figured out it was the fog lights when I got home & hubby said "why are your fog lights on?" Found out from other owners on the web that this is not unusual - multi-function switch design flaw (I could also keep my blinker down to turn them off but I was afraid I'd forget). Anyway, learned I could pull a fuse (#8) to remedy the problem since I never used those lights anyway. All was well - fog lights off and nothing else affected as far as I could tell.
BUT - since I replaced my battery and pulled that fuse my MPG has dropped from 18-19 to 13. WHAT?!?!?!!? I would think a new battery would have just the opposite affect. Plus, I just spent over $2k on a ton of things to get the old girl up to snuff (that was 6 months ago, and my MPG didn't go up or down after all the work was done - although I was told performance should increase - not that I could tell - oh, well). Anybody have any idea if pulling the fuse or a new battery could be causing this? It just doesn't sound plausible. All thoughts are welcome!
PS - I am in the US, this isn't an exported PT.
Old 14 May 2012, 04:49 am
Default Re: Drop in MPG
Pulling the #8 fuse or replacing the battery, as you said, shouldn't have anything to do with mileage EXCEPT that whoever changed the battery out could have done something that might have affected it. The multi-part air filter has to come off to get to the battery and things could have been moved or messed with that might cause the mileage to drop. There's a couple things attached to the intake hose including a vacuum hose and a sensor called the IAT. Possibly the tip of the IAT was broken off (easily done) if it was removed and put back in. If it was, that measures the incoming air and would mess up the air/fuel mixture. Only a thought, but worth checking.
Old 14 May 2012, 03:31 pm
Checked the IAT sensor and it's just fine. No hoses are lose. I'm bummed. I was hoping the IAT sensor was the problem....but, maybe it is - could be it's not working correctly. New one is under $40 so maybe I should just replace it?
Thanks for your reply, CREWZIN!
Old 14 May 2012, 03:46 pm
Sorry, I'd say if you still have the little blue tip on it, it's probably doing it's job. Gotta be something else but again, if it started with changing the battery, should be something to do with a part that was moved or broken or forgotten to be put back.
Old 14 May 2012, 03:51 pm
cruserdad1976's Avatar
question is are you using the dash MPG or are you actually doing the math?????
Old 14 May 2012, 08:29 pm
mdfrodolives's Avatar
Have you done the key dance? Just a thought ....
Tim
Tags
fog lights, fuse 8, mpg
MPG drop in winter edb General PT Cruiser Discussions 6 19 Dec 2010 03:14 am
MPG Drop jbcrzn General PT Cruiser Discussions 15 24 Jun 2010 10:30 am
Drop it like it's HOT 808 Wheels, Tires, Suspension 48 03 Sep 2009 02:11 pm
Drop top from Germany CREWZIN PT Cruiser Convertible Forum 0 03 Dec 2004 09:55 am
K&N drop in mcruz Turbo Wheels/Suspension/Handling 2 13 May 2004 10:11 pm
