My Pt Gt has been acting weird.
Like Tree2Likes
Old 15 May 2012, 10:24 pm
Talking My Pt Gt has been acting weird.
Recently I've noticed that the turbo has been making a slight noise when spooling kind of sounds like a constant whistle. It may be a boost leak but idk how to tell. Also today my exhaust began putting out clouds of huge white smoke at random moments. Could it be a head gasket? Turbo seal? There are no engine codes and car hasnt been overheating. It runs fine but to me I feel like something's wrong. Can anyone give me suggestions?
Purple 2005 PT GT ATX w/ Mopar stage 1 PCM, Diablosport 93 oct tune, airbox mod, K&N drop in filter, Mopar BOV, AGP wastegate (8 psi spring), Custom made stage 1 camshafts, motor mount inserts, NGK Iridium plugs, MSD wires, ARP Head Studs, Gates Racing Timing Belt, AC Delete kit, purple painted Valve cover, Rebuilt (stock) Turbo , AEM Boost, Oil Pressure, and Wideband guages, triple guage A pillar pod, Strut Tower brace, Needswings 3in o2 housing, 3in downpipe w/ high flow cat and electric cutout, 2.5in Magnaflow catback, custom check valve, custom larger capacity trans cooler w/ built in cooling fan, Eibachs pro lowering springs, KYP front and rear struts, matte black hood and grille, gloss black stock SRT neon rims, purple lug nuts, blacked out tailights and reflectors so far. Built and bored out motor, AGP S256 turbo, ported cylinder head, and built trans soon to come.
Old 15 May 2012, 10:28 pm
Kawizx9r's Avatar
Default Re: My Pt Gt has been acting weird.
Whistle type noise is normal.
As far as having a 'leak', well...do you have a boost gauge? I think I mentioned it to you as well as others that, this gauge is a monitoring tool. If your boost is still the same as it's been before, then no...don't think you'll have any leaks. A whistle-type noise is perfectly normal and usually more apparent when you do mods to your intake/etc. Ever heard a semi-truck driving from a dead stop? That loud hiss/whistle is the turbo working up which gives the engine the extra-needed torque to get moving.
As for the white smoke; go to the rear of your car and smell it. If it's a somewhat 'sweet' scent, sure enough you're burning some coolant. If it's a blueish-hue, that'd be your turbo.
XtrmDC2 likes this.
My Toy
Kawi is a friggin genius!
Old 15 May 2012, 11:11 pm
Talking Re: My Pt Gt has been acting weird.
Gotcha will do, thanks Kawi I'm gonna take a look a lt a few things myself tomorrow but I'm definitely taking it to my mechanic because I feel like my pt isn't running at full capacity
Old 15 May 2012, 11:24 pm
ROCKETMAN8060's Avatar
Just make sure not to race it until you find out what's wrong with it!!!
ROCKETMAN8060
Old 17 May 2012, 08:33 pm
Yeah I'm gonna be gentle with it. But does anybody think that it could be my stage 1 causing the issues? I kno the stage 1 makes ur motor run a little rich. Can running slightly richer give u white smoke out the exhaust? So far my mechanic checked the motor itself it's not a head gasket or valve cover gasket. Motor is rock solid. Time to check the turbo itself now.
Old 17 May 2012, 08:39 pm
Don't think the Stage 1 will give you a problem like that! Take the hose from the intake of the turbo, try to grab the shaft of the turbo and try to move it side to side to see if it has some play! It can probably be the bearings and you may need to rebuild the seals and bearings.
ROCKETMAN8060
Old 17 May 2012, 09:22 pm
Ok I'll let my mechanic kno, is that an easy fix tho???
Old 17 May 2012, 10:12 pm
It is if it doesn't have major mechanical problems. It doesn't sound to me that's your case!!!
ROCKETMAN8060
Old 18 May 2012, 06:43 am
Smile Re: My Pt Gt has been acting weird.
Sweet
Old 22 May 2012, 09:39 pm
Angry Re: My Pt Gt has been acting weird.
Well after having my pt looked at it turns out my issue with the engine is that it's blown, I only have 70k miles on the car does this make sense???
PT is acting weird when A/C is on the_jeep_now Tech & Performance Forum 13 22 Aug 2011 09:42 am
Sunroof acting weird Franksredpt General PT Cruiser Discussions 2 10 Apr 2009 11:12 pm
So my Trans MIGHT be acting up? Cathy06PT Tech & Performance Forum 6 11 Nov 2008 10:57 am
Dash acting weird Nikkortim General PT Cruiser Discussions 8 04 Sep 2005 06:30 pm
My PT is acting up at 68K miles (VERY BAD) Ctown General PT Cruiser Discussions 2 11 Mar 2005 11:10 am
