Stops dead, then starts again.
Old 17 May 2012, 01:51 pm
Default Stops dead, then starts again.
My wives 2001 PT Cruiser 2,0 (European model) stops dead, but then starts again like nothing had happened. This can happend several times a day, for then disappearing in weeks. And now its back... Anyone experiented this?
Old 17 May 2012, 03:02 pm
Default Re: Stops dead, then starts again.
Never happened to me but I was working today for the Sheriff's department and went to a 3 car crash. Lady's Dodge Caliber up and died for no reason and she was traveling about 55mph. Everybody behind her scrambled and 3 cars were involved, not hitting her but each other as they tried to get around. So it doesn't just happen to the PT, but might be a Chrysler/Dodge thing.
Sounds like electrical shutdown but a lot of work with tracing down the fault. Could be the ignition, battery or electrical system to do with the fuse boxes.
Old 17 May 2012, 04:41 pm
Yes, I guess it is electrical. What abouth that shut down switch?
Or should I replase the spark plugs, cables, coil and the battery?
Old 17 May 2012, 04:54 pm
Yes there's a ASD fuse in the fuse box in engine compartment if yo have an 01-05 cruiser. I wouldn't go replacing anything without first testing.
Old 20 May 2012, 08:06 am
Drove 1000 kilometer this weekend, no problem! But I know it will be back...
Old 01 Jun 2012, 12:57 pm
Today its here again, stopped dead then started again some minutes later. Happened twice. I did the ignition switch trick and got code p 1684 and p 320.
Do the code indicate a defect camshaft position sensor?
Old 01 Jun 2012, 05:50 pm
P1684 just means the battery has been disconnected within the last 50 starts.
P0320 is no reference signal from Crankshaft position sensor detected during cranking.
Old 02 Jun 2012, 03:48 am
The battery has not been disconnectet the last year or so. Could resetting occour when the car dies?
What does code P 320 mean?
Old 02 Jun 2012, 07:16 pm
Boy... this sounds just like the problem I had with my GM truck while towing another car. While driving on the highway at 65 mph, the truck all of a sudden cut-out for a couple of seconds... then fire back up...was like riding a "bucking bronco". After a few of these "bucks", i turned the key off and coasted to the shoulder. Though I would lose the trailer w/ car.
It restarted, I went a few miles then it completely died. Had to get both towed off the highway ($) to a Dealer.
Turned out to be the Crank Sensor.
Old 03 Jun 2012, 09:11 am
Its quite spooky, no problems the last two days.
Is the crank shaft sensor and the cam shaft sensor the same thing?
When I think back, most of the time it died was when I was prepearing right turns. When I use the right turn signal, the indicator light for the foglight turns on.
Starts and stops again? daggie Tech & Performance Forum 10 20 Oct 2012 08:33 am
A really odd problem - flicker, then dead, then starts back up bobdole369 General PT Cruiser Discussions 11 14 Feb 2012 06:23 pm
CRD starts and stops richard162 Tech & Performance Forum 1 20 Nov 2011 11:24 am
PT starts bad ProDigit General PT Cruiser Discussions 5 03 Nov 2010 02:23 pm
The Pt starts hard LNBNDN General PT Cruiser Discussions 1 03 Jun 2010 08:14 am
