PT Drivers Side Squeaking
Old 18 May 2012, 05:29 pm
Default PT Drivers Side Squeaking
Ive had a loud squeak on startup for the last 6-8 months and its driving me nuts. It seems to get worse if I start the car on a slope. The squeak is coming from the drivers side, so i'm thinking it could be the mount thats located under the battery tray? Here's a video of the noise..
Old 18 May 2012, 10:58 pm
fabreezai's Avatar
Default Re: PT Drivers Side Squeaking
Although it sounds like it's coming from the drivers side, I would say that's a belt "squeak" from the sound of the video, more than likely from the alt belt since the other belt has a automatic tensioner on it. I would tighten the alt belt and see if goes away. When was the last time the belt's were changed?
Cheers! 2003 2.4, N/A, Touring, Supercharged, 5 speed. 126k..... Blew up that engine, building another to take the boost! Built a new engine, still working out some issuess.......
Old 19 May 2012, 09:03 am
No idea when the belts were last changed; I picked up my PT from Enterprise rent-a-car with 40k on it, now at 72k.
Ill inspect the belt and check the tension.
Old 19 May 2012, 11:04 am
davea300's Avatar
Mine does the same. I'm 99% sure its the alt belt as well. There are threads here on the correct procedure for tightening
2005 2.4 PT CRUISER (UK SPEC)
Short ram intake, chrome grill, chrome belt line, drilled/slotted discs, few flames, engine dress up, chrome bits and pieces.
67,000 miles
Old 21 Jun 2012, 08:07 pm
Had the same problem, it was the serp. belt squeking on the tensioner not enough pressure being applied to the drive belt. new tensioner 12.60$ and 1 hour of sweat. = no more noise.
Removing drivers side cargo area side panel Jtwheels2007 Interior Accessories Forum 2 26 Mar 2012 08:03 pm
Key does not work in drivers side door adriennemetalsmith Sound and Security Forum 4 02 Jun 2010 07:07 pm
Drivers Side Gets Loud TwoToneTommy Wheels, Tires, Suspension 3 24 Feb 2010 09:12 pm
Some A-hole cut my top on the drivers side MINIHEMI46 PT Cruiser Convertible Forum 21 02 Jan 2010 11:37 pm
Drivers Side Headlight 2k1PT Classifieds: Want To Buy 2 23 Aug 2008 03:39 pm
