leak somewhere
Old 18 May 2012, 10:18 pm
Default leak somewhere
Hi all,
first time here, and hoping you can help.
I seem to have a small leak somewhere in the car. At this stage when i fill the radiator with coolant it drips out somewhere and after a while its all gone.
It could be a loose clamp on the car, but not sure where i need to be belooking.
I hope that its not a crack in the radiator, so any help would be great.
thanks
Old 18 May 2012, 10:31 pm
Kawizx9r's Avatar
Default Re: leak somewhere
Originally Posted by renderman7 View Post
Hi all,
thanks
Hope I don't sound 'mean' in how I say things but it's kind of a given as to where to start but I'll give you some help.
If you've got a leak, the first place I'd check is the ground immediately under the car.
You can get a good idea of where a leak is dripping from or where it's trailing from.
Visually inspect under your vehicle as well; more specifically look at any and all cooling components such as any hoses that lead to and fro the radiator.
I just had to replace my friends radiator about 2 days ago and created a walk-through on how to do it, very picture-friendly too so that will come to use if you need it (let's hope not). Another thing is, when your car is on...do you notice any whiter-than-normal smoke coming from your exhaust pipe? The smell would be slightly sweet too since coolant has a nice sweet smell to it.
PS Hope you're refilling your coolant with HOAT. Don't use the regular green-add-to-any stuff.
Kawi is a friggin genius!
Old 18 May 2012, 10:33 pm
Kawizx9r's Avatar
One more thing; welcome to the forum!
Should edit your profile to state where you're located at.
Old 19 May 2012, 07:31 am
Do you really mean to say you have a leak IN the car?
If indeed, it is IN the car, the most probable cause is a leaky heater core.
Oil leak revolta General PT Cruiser Discussions 4 10 Dec 2011 09:23 pm
HELP!!!! bad oil leak prfectpair Tech & Performance Forum 7 28 Jul 2011 12:06 pm
Oil Leak sweettee Tech & Performance Forum 3 30 Aug 2010 04:18 am
ATF Leak shlalk General PT Cruiser Discussions 12 24 Mar 2004 09:05 am
First Oil Leak? Ack! beebs General PT Cruiser Discussions 4 18 Oct 2003 10:55 am
