code 0340
Old 19 May 2012, 07:16 pm
Default code 0340
My 2007 pt cruiser check engine light came on and seconds later my car stalled then would not start. The codes that came up were p0340 and p0016. Both are for cam shaft position sensor. We replaced it and car will not turn over. Almost sounds like its missfiring. No codes come up and we have tried resetting the computer in a few different ways. Why wont it start now? My only transportation!! Please help!
Old 19 May 2012, 07:45 pm
cruiser04's Avatar
Default Re: code 0340
Code P0016 is for Crankshaft/Camshaft timing misalignment.
1. When replacing the Camshaft Position sensor, did you make sure when installing the target magnet that the locating dowels on the back of the magnet where aligned with the locating holes? Also the CMP sensor retaining bolts need to be torqued at 115 in-lbs. The CMP sensor target magnet retaining screw needs to be at 32 in-lbs
2. Did you replace the Crankshaft Position (CKP) sensor too? The torque speck for that is 80 in-lbs.
Old 19 May 2012, 07:56 pm
just to add something: what is your mileage? If a code for both the Cam and Crank sensors came up, it might mean your timing belt has gone south.
Tags
cam shaft position sensor, code p0016, codes p0340
0340 Code Jaimez Tech & Performance Forum 20 20 Sep 2011 01:21 pm
Error code P0456 & 0340 RoadTramp113 Tech & Performance Forum 12 21 Feb 2011 08:29 pm
Error code 0340 Callygirl Tech & Performance Forum 6 22 Nov 2009 10:30 am
Engine Code 0340 PTTurbophile Tech & Performance Forum 9 12 Mar 2009 03:46 pm
Error Code 0340 KingKole02 Tech & Performance Forum 16 02 Oct 2008 04:05 pm
