2005 PT cruiser idle problem
Old 20 May 2012, 02:48 pm
Default 2005 PT cruiser idle problem
I have a 2005 limited edition PT cruiser. I have had problems with the car shaking while in idle and has stalled a couple of times. When the problem first arose, I took the car in and got brand new plugs and wires. This did not fix the problem. A few weeks later, I replaced the coil pack and it did not fix the problem. The car has approx 84,000 miles on it. The vibrating goes away when the car is not in idle; however, the problem has gotten progressively more frequent. Any other ideas? Oh, when I take the car to get diagnosed, it does not run a code. Thanks for the help!
Old 20 May 2012, 03:00 pm
Default Re: 2005 PT cruiser idle problem
Is the A/C running when it's doing all that shaking? If so, does it stop shaking when you turn the A/C off?
Old 20 May 2012, 03:02 pm
It shakes when the AC is off and it shakes when the AC is on. In fact, my AC does not work well when the car shakes.
Old 20 May 2012, 03:24 pm
Is the fan running. Lots of problems with the radiator fan burning out on one speed or the other and that will cause the engine to shake when it get overheated. When you get going, the fan isn't needed as there's air flowing in through the radiator but when yo slow down or go to idle, the air flow stops and the fans needed to keep things cool.
Tags
idle, pt cruiser 2005
2005 PT goes to idle on the highway? unioncreek General PT Cruiser Discussions 1 04 Apr 2012 01:38 pm
2005 PT Cruiser GT Problem PLZ HELP!!! avaracer182 General PT Cruiser Discussions 1 19 Dec 2011 12:46 am
2003 PT Cruiser idle problem oscar514 Tech & Performance Forum 2 12 Sep 2009 11:17 pm
2006 pt cruiser idle n loss of power problem chickon35 Tech & Performance Forum 4 30 Sep 2007 04:35 pm
2005 PT Cruiser GT only 6500 miles idle issue... batlin General Turbo Discussions 4 18 May 2007 07:35 pm
