Engine Support Bracket Bolts ???
Old 21 May 2012, 10:16 am
Default Engine Support Bracket Bolts ???
I'm trying to help a friend via Long Distance that is trying to reassemble a "basket case" PT Cruiser (2001 or 2003).
He's confused about the bolt holes for the Engine Support Bracket and where they line up. The Timing Belt covers are on. Are the marked images labeled #1,#2,#3 the mounting holes for the Engine Support Bracket?
I can't remember if the locations marked as #1 is the also the Timing Belt Tension bracket hole and the hole marked #2 is also the Water Pump bolt hole?
To mount the Support Bracket, it looks like you need some long bolts... he says there are already short bolts installed in #1 and #2, not long enough to be used to mount the Support Bracket into #1 and #2 (won't reach). They may have used the short bolts just to install the Water Pump and Tensioner (for setup)... don't know. Didn't come with long bolts (if needed, anyone know the size?).
Thanks.
[IMG][/IMG]
Old 21 May 2012, 12:28 pm
UptownSport's Avatar
Default Re: Engine Support Bracket Bolts ???
Originally Posted by SteveG22 View Post
the marked images labeled #1,#2,#3 are the mounting holes for the Engine Support Bracket.
the locations marked as #1 isn't the Timing Belt Tension bracket hole, as it's already installed in another hole per photo
The hole marked #2 passes thru the Water Pump
To mount the Support Bracket, you need some long bolts...
Thanks.
You're correct.
You have the litens tensioner pictured, I have 0 experience with them- Just ask you friend to place bracket against engine, it would be rather obvious if all lines up correctly.
A handy reference is the Factory Parts Manual- There's a link in my signature to Chrome's collection - It should give you the size of bolt (along with Mopar part number)
I'd likely have some for cheap if he's in a real bind.
Old 22 May 2012, 04:37 am
Well i downloaded the Parts Manuals for 01-04 and this seems like the only part (Engine Support Bracket) they skipped over... what are the odds
In one of the diagrams they label the T55 bolt but no where else are the three Support Bracket bolts illustrated.
Old 22 May 2012, 01:17 pm
Same thing here- can't make any sense of it either
Timing belt (Factory) was skinny, shreds against engine support bracket gopbroek Welcome New PT Cruiser Members 1 13 May 2012 10:27 pm
Engine support bracket minger Tech & Performance Forum 4 30 Apr 2011 09:13 am
need right engine mount bracket csd Classifieds: For Sale/Trade 6 17 May 2009 07:45 pm
right engine mount bracket csd Classifieds: Want To Buy 0 04 May 2009 11:26 am
Replacing Timing belt: Engine support question cardana24 Tech & Performance Forum 4 21 Mar 2008 07:55 pm
