need help swapped engine no start
Old 21 May 2012, 01:02 pm
Dimitry's Avatar
Send a message via Skype™ to Dimitry
Default need help swapped engine no start
hi, just swapped and engine on 2001 pt cruiser automatic transmission to a lower mileage one it cranks and the crank cuts off and sometimes rpm arrow goes to 8000 rpm and fuel pump works non stop on non turned engine and ASD relay ticking loud here is a list of codes i able to pull out :
P1299 - high fuel pressure
P1391 - cam/crank bad signal
P0183 - high fuel temperature
P07E5 - ?
U2575 - ?
P0340 - cam shaft sensor circuit malfunction
if anyone had similar issue or know how to fix please post thank you
03 PT black 2.4 turbo manual. mine
02 PT silver 2.4 n/a manual. wify's
01 PT inferno red limited edition 2.4 n/a auto. mom's
Old 21 May 2012, 01:19 pm
UptownSport's Avatar
Default Re: need help swapped engine no start
What year is donor engine?
People used to get coil / cam sensor connector mixed up
Old 21 May 2012, 01:30 pm
Dimitry's Avatar
Are they the same? If so that can be my issue but why then when I put key in 2nd and fuel pump usually pumps the pressure then stops and in my case it continuesly pumping fuel and I get high pressure fuel error is it somehow connected with can and ignition coil? And donor was same 2001 identical engine
Old 21 May 2012, 03:13 pm
I **Believe** Fuel pump shuts off when it doesn't see a cam sensor and/or crank sensor signal-
(Therefore it shuts off fuel pump in case of crash)
I'm not smart enough to tell you what would cause PCM to not shut off otherwise- If it believes its getting appropriate signal for some reason or ...
My strong suggestion is to contact Chromenut and see if he can get you a 'line' on a FSM- It'll tell you everything you ever wanted to know about the various systems, and exactly which wire goes where.
I'll add the crank, cam, coil and VSS (MTX) are same connector.
Old 21 May 2012, 08:06 pm
Dimitry's Avatar
you're the man after switching cam sensor with coilpack i was able to crank it up and start was running a bit rough but after 15 min much better but i still have that cam sensor malfunction probably when the cam sensor had coilpack wiring on it killed the sensor ?! anyway will buy a new one tomorrow as it takes more crank to start the car
Old 21 May 2012, 09:55 pm
Good to hear- Cam sensors seem to fail for any reason or no reason- so wouldn't fret about it, prolly just decided to die
whats the best way to start engine? niel General PT Cruiser Discussions 9 16 Mar 2012 12:08 am
Engine will not start decoyboy Tech & Performance Forum 6 15 Mar 2012 09:02 pm
Swapped my PT, but have a new problem... ABS & TRAC OFF Lights on.... stek2008 General PT Cruiser Discussions 7 16 Dec 2010 08:27 am
2006 GT - Swapped Engine Vaccum Hose problem wendelltu General Turbo Discussions 8 12 Aug 2010 05:12 am
swapped my wheels REDanan Turbo Wheels/Suspension/Handling 10 25 Oct 2007 11:13 am
