oil leak around head?
Old 22 May 2012, 06:20 am
mdskinner731's Avatar
Default oil leak around head?
while driving my pt cruiser it alwas leaves oil on the ground no matter where i park? last night i think i figured it out. upon inspecting every thing i noticed oil seepimg out from around my head gaskest. which is odd because its a brand new head gasket; new head bolts; shaved head with a clean block. (bolts torqued to book specs) has any one else encountered this delima before??
*** HELP ***
if it moves and not supposed to... duct tape!!!
if it dont move and is supposed to... WD-40!!!
~* the problem with america is warning labels.... take them off of every thing and eventually the stupid people will die off... *~
Old 22 May 2012, 07:35 am
Default Re: oil leak around head?
sounds like either the head gasket is bad, or you have a small deformity in the head itself. if everything is torqued correctly it shouldnt leak unless something is giving.
Old 22 May 2012, 07:46 am
This is highly unlikly without antifreeze lose. But anything could happen. Were exactly is the oil seem to come from.(front,back, left, or right) side of the engine?
No shim on head installation right?
Old 22 May 2012, 08:39 am
chigger_ns's Avatar
Did you mean it leaks around the valve pan gasket?
2001 PT 5 speed Touring Edition
Eibach Pro Springs, Energy Suspension HyperFlex Master Kit bushings, 17" RTX Euro wheels, K&N drop in air filter, MotoMaster flat plate AGM battery, KYB GR2 shocks and struts, Booger standard shifter bushings, Ooogah horn.
Old 22 May 2012, 08:44 am
every thing was torqued in order and to the correct specs. ( cant remember exactly what that is but i followed the service manual i have) yes the head was shaved and assembled with 1 gasket. and new head botls. no metal shims were used.
looking up at things from the bottom.(while its on my lift) the head is clean as a whistle all the wat around it, then every thing below the head is all covered in oil and road grime.
Old 22 May 2012, 12:48 pm
UptownSport's Avatar
Composite head gaskets ('93-'97?) used to leak at driver's rear- Right above oil sending unit.
Of course, oil sending unit leaks-
And cam sensor-
Rear main will likely just seep if at all-
The torque spec adds 1/4 turn- Sometimes people forget this last part, or forget one in the sequence (It's best to use paint and daub a little on each bolt head during sequence)
You could pull valve cover and check each bolt- Somewhere on neons.org someone has done a
reading of actual torque reached at end of the 1/4 sequence- Don't know/remember what it was.
There's only two headbolts you can't easily get to with cams in, if you use 3/8 extension with wobble you can do a 'good enough' check.
Old 22 May 2012, 01:38 pm
thank you "uptown" and every one else! i will see what i can do to check these this weekend, as i cant afford to keep driving the rusty but trusty blazer. keep any and all ideas coming. BTW what is in the front of the engine that could potentially leak oil? most of my drips are towards the front center of the engine (if that makes since)
Old 22 May 2012, 03:50 pm
Bedplate, oil pan gasket
Old 23 May 2012, 09:03 am
"Bedplate" huh??
lol
Old 23 May 2012, 09:59 am
check the valve cover gasket.
Seeing as the Cruiser has a NEON engine haha neons are very well known for haivng VCG leak issues, i had a massive leak, turns out it was a $30 gasket, took me 45 min to swap and in the past i've had to replace the VCG 3 or 4 times in a row before i got one that sealed correctly.
Oil leak = head gasket? DawnTN Tech & Performance Forum 11 11 Jun 2012 09:47 pm
Whats the Head flat spec. for head gasket. Busted_PT Tech & Performance Forum 7 26 Apr 2012 08:16 am
WARPED HEAD / SCORED CAMSHAFT / BLOWN HEAD GASKET amadeo Tech & Performance Forum 5 12 Apr 2011 01:03 am
Head Gasket Leak?? cruisrman General PT Cruiser Discussions 7 23 May 2005 10:50 am
Odd Oil Leak GTPT Turbo Performance 5 27 Aug 2004 03:39 pm
