short circuit...but where?
Old 22 May 2012, 06:51 am
Default short circuit...but where?
Hi, I have a 2001 PT and while trying to wire wire in manual toggle switch to control my radiator fan (don't ask), I shorted something out.
Facts: with key in on position (or trying to start car)
Won't start
No radio
No dash cluster lights
No power to windows, sun roof, blinkers, windshield washers
BUT, I can control the defrost fan when turing the ignition to on
However, I have head lights, parking lights, 4 way flashers, dome light as normal.
I've checked with ohm meter (or swapped out) all fuses under dash and under hood, relays etc. but all seem to be good. From the wiring diagragm, seems like it should be the 30 AMP fuse under the hood, but even if i take one of the 40 amp fuses and place it in that socket...nothing.
Is there any other fusible link other than the one between he starter and alternator??
I'm no longer worried about fixing the issue with the radiator fan....that I can understand. Thnaks in advacne for any advice
Old 22 May 2012, 09:07 am
Default Re: short circuit...but where?
Seems to me, under hood fuse #1 (ignition start) or #13 (ASD) should be the ones to carefully look at.
Old 23 May 2012, 07:26 am
Thanks...as it turned out, it was the 30 AMP fuse under the hood in the PDC. Took 5 minutes in the garage to determine that. Strange thing, the fuse tested good with my meter so I never replaced it. UGH...waiting to pick the car up to see how much I owe for that snaffu.
Old 23 May 2012, 09:39 am
You mean the No#1 30 Amp (Ignition start)? I took a good guess there, huh?
Sorry that a garage/dealer had to find it, but you said it tested good? Strange.
Old 23 May 2012, 10:05 am
i had this issue out of the blue, but it wasnt a fuse. all lights just went dead while driving down the road one day, turns out it was a fusable link.....ran me $75
HELP I caused a short circuit!!!! niel General PT Cruiser Discussions 6 23 Feb 2012 12:53 pm
PCM Knock Sensor Circuit?????? turbonate2003 General Turbo Discussions 11 19 May 2011 06:52 pm
2001 EGR Solenoid control circuit flowerpot Tech & Performance Forum 0 12 Jan 2009 08:11 pm
Cooling circuit Kirby General Turbo Discussions 3 03 Aug 2008 05:49 am
Fog Lamp Circuit SILVERONE Exterior Accessories Forum 8 04 Jan 2004 10:40 pm
