Gurgling noise under the hood
Old 26 May 2012, 06:40 pm
Default Gurgling noise under the hood
I hear a gurgling noise under the hood occassionally when the engine is first shut off. Until today, the car was not running hot...just a little gurgling. Today however, the car started running hot. It doesn't seem to be loosing any anti-freeze.
I recall seeing a similar post where it was suggested checking/replacing the radiator cap, so under the hood I went. The radiator cap is marked 18 lbs., and I was wondering if this is the correct cap, it actually looks new, however this is the same dealer who screwed up my sway bar links (which I posted prevoiusly...and they did replace)
Any helpful suggestions?
Old 26 May 2012, 07:04 pm
Default Re: Gurgling noise under the hood
I believe the original cap is 16lbs. Even if you replace it, have a pressure test done and make sure all the air is out of the coolant system.
Gurgling noise under hood. mchali Tech & Performance Forum 7 26 Apr 2012 02:14 pm
gurgling noise in top end scottsinfl Welcome New PT Cruiser Members 19 04 Nov 2011 05:24 pm
Howling, gurgling, & popping when I accelerate? Help! ChicagoPT General Turbo Discussions 6 25 May 2011 07:44 pm
Gurgling sound under hood..... KIMS CRUZER Tech & Performance Forum 3 20 Aug 2007 05:57 pm
'Gurgling' Noise ? TripleJackInGA Turbo Performance 9 30 Nov 2003 06:12 pm
