Engine miss upon deceleration
Old 26 May 2012, 09:41 pm
Default Engine miss upon deceleration
I posted awhile ago about a really baffling issue I had with what seemed to be a misfire whenever I decelerated around 60 mph. Had no fault codes or anything else to help diagnose. Well, I discovered the cause today when I had the hood up and the motor running to check the transmission fluid level. I heard this loud hissing noise that I obviously hadn't heard from inside the car when it was running.
It turns out that there is something that looks like a little in-line filter which connects to a rubber elbow on the back of the power brake booster. It had become disconnected and was just hanging down, with the elbow wide open. As soon as I put my finger over the end of the elbow, I could feel the vacuum and the idle got lower. Cleaned it up and added a cable tie to snug it up. What a difference! This has had me on eggshells for quite some time, letting my imagination drive me nuts. All I can say is that I'm glad I finally figured it out it, and also DUH!!! to myself for not thinking of something vacuum-related sooner than this.
Old 26 May 2012, 09:57 pm
Default Re: Engine miss upon deceleration
Thanks for letting us know what you found. Might help others in the future.
Old 27 May 2012, 07:20 am
Glad you got it fixed! Thanks for the follow up. Going to happen again to somebody.
engine miss fire bhunt41 Tech & Performance Forum 0 14 May 2012 09:37 pm
Engine Miss On deceleration sscanlan Tech & Performance Forum 9 01 Oct 2011 05:26 pm
Still having engine miss problems robbie109 General Turbo Discussions 17 22 Sep 2011 05:38 pm
03 Stage 1 2.4 Engine miss/bucking getuoutthere Stage Turbo Kits 7 15 May 2011 04:29 pm
Can't figure it out! Engine "miss" in all gears garlin Tech & Performance Forum 2 19 Jul 2003 11:58 pm
