08 Air Conditioner Issue
Old 26 May 2012, 10:06 pm
Default 08 Air Conditioner Issue
Hi Guys,
On my 08 PT automatic (65,000 miles) I have been having a problem with bad stumbling when I turn on the air conditioner.
In Fact, it stumbles so bad it almost dies at idle.
It seems to clear up after 8-10 miles buy obviously something is not working correctly.
When I come to a stop light there is about a 75% chance it will stumble again, Not EVERY time, but more often than not.
The fans seem to be working just fine, but I did notice that at idle I do not get much temperature drop either.
Any Idea's on what should be checked?
Old 27 May 2012, 07:07 am
Default Re: 08 Air Conditioner Issue
You'll have to clarify the part about the fan "seem" to be working. It does or it doesn't.
Wait till everything is cool. Open the hood, see if you can see the fan when it's not moving. Start the car and turn on the A/C and go loo at the fan again. It should be turning. On low speed it's hard to hear or see but you have to confirm if it came on. It should run every time the A/C is switched on.
Old 27 May 2012, 10:24 am
Seems to be fine meaning that the fan does come on as expected. The problem is the engine stumbles to nearly dying at idle. Once in motion the car is responding normally.
Its like the idle does not compensate when the compressor kicks in? Or lets say that it how it feels.
It (engine)vibrates and shakes, the tachometer drops to a very low reading and on more than one occasion I had to restart the engine.
Everything was fine last summer & fall, and we did cycle the air several times over the winter on warmer days. It just started happening a few days ago.
Also, in talking to my daughter, hers started doing the same thing recently. Hers is an 06, coincidence? or is there a common problem?
Old 27 May 2012, 10:41 am
The computer compensates for the drain of the compressor when it kicks on. Mine raises and drops almost 200 RPM's when the compressor cycles.
You might just trying to reset the computer. Take the negative battery off for about 5 minutes. Step on the brake peddle while the battery is disconnected. Then put it all back together. It's like a reboot on the home computer, clears a lot of small things.
Old 27 May 2012, 10:54 am
OK Will Do.
We do occasionally get a few electronic oddities in this car. One time the window stuck down, restarted, it was fine?
Old 27 May 2012, 12:22 pm
Just to be clear, the fan that Crewzin is talking about is the radiator fan at the front of the vehicle. The reason I bring it up is that your issue REALLY sounds like it could be a bad radiator fan. Believe it or not, that would cause rough idling and stumbling when the A/C is turned on, and it's a VERY common problem on PT's.
Old 28 May 2012, 06:35 am
Yes, I know which fan he meant, I replaced a fan on my 01 several years back along with the radiator that was leaking.
Now is the fan possibly intermittently bad? that remains to be seen. Since checking it while driving is just a tad difficult.
I'll do the reset this morning and then report back.
Old 28 May 2012, 12:12 pm
^^^X2. At idle it should be running all the time with the air on!
Old 28 May 2012, 09:28 pm
mdfrodolives's Avatar
Do the fan test that's in a sticky on this forum. Both low and high speed. sometimes (a PT mechanic told me) a bad fan is not ALL bad. Sometimes it works, and sometimes not. That's an indication that soon it will not work at all on one or the other speed.
Do the test, using jumper wires and the battery on the fan connection.
Tim
Old 13 Jul 2012, 01:11 am
I have same problem. Where is"fan test in sticky on this post"?
Air conditioner question MOPAR_GIRL Tech & Performance Forum 5 03 Apr 2012 08:38 pm
Air Conditioner Air Conditioner Vaccuum or Flap seal issue??? RMThompson General PT Cruiser Discussions 7 25 Feb 2012 02:40 pm
Charging the Air Conditioner chuck2112 Tech & Performance Forum 11 23 Feb 2010 09:44 pm
Air conditioner probs. ccinder General PT Cruiser Discussions 2 18 Jun 2008 09:35 pm
air conditioner smell aimee_in_TN General PT Cruiser Discussions 9 17 Jun 2004 11:02 am
