non typical blown head gasket
Old 27 May 2012, 01:37 pm
Default non typical blown head gasket
no water in oil, no water out tailpipe, car would boil coolant and boil in overflow tank, no pressure boil over, negative reaction on radiator fluid test. Gauge at 3/4 after freeway driving. ok around town. What do you guys think ?
Old 27 May 2012, 01:53 pm
Default Re: non typical blown head gasket
That picture came from another member, right? Not your car?
What makes you think it's a blown head gasket?
Old 27 May 2012, 05:11 pm
wheelgarage's Avatar
Same issue I had....
The coating on the HG is gone. The amount of water that gets in the combustion chamber gets completely vaporized. The amount of pressure from each cycle pushes the hot gases back into the cooling system. In turn, boils all the coolant in the system...one way out... the tank.
Remember to replace the water pump with a Mopar unit and use Reline Water Wetter for more cooling control. Good time to rebuild the head also...
2005 Touring Black - Automagic....California Smog Legal
H&R Cup Kit | TSW Sakata 18x8 35ET | Nankang NS-II 235/40/18 | SPC front alignment cam - rear shim | Master Pro Rotors | Master Pro Ceramic F/R pads | Rebuilt Cylinder Head - Safety Valves and Guides | Felpro Head Gasket and upper rebuild kit | Fail-safe 195 degree thermostat | Mopar Waterpump...lol | 3rd radiator fan motor | Gates timing belt kit | WIX filters (oil, transmission) | Mobile 1 5w30 | Mopar ATF4 | Redline Water Wetter | K&N Drop-In | 4th Drive side Axle | Energy Suspension Torque Mounts | 3rd set of Torque Mounts...
Old 27 May 2012, 07:27 pm
UptownSport's Avatar
That pic looks like it leaked between cylinders- No coolant there
Old 27 May 2012, 08:46 pm
Nope its my car
Old 28 May 2012, 02:40 pm
More pics of the HG?
Old 28 May 2012, 09:40 pm
gvc2000's Avatar
i blew mine because i suspect the fan wasn't working. it happened rather quickly but it didn't notice the temp rising to over 3/4 and engine cut off. after putting on a new head etc the fan wasn't working right. these guys say gaskets are a problem normally and i will take their word. but something jacked it.......well the fan seems fine now but i'll pay attention to temp more often now and check fluids regularly.
Old 28 May 2012, 10:30 pm
I think wheelgarage has something here
Could this be a blown head gasket? iowabucks Tech & Performance Forum 75 07 Aug 2015 10:19 pm
Blown Head Gasket? sweng40 General PT Cruiser Discussions 20 14 May 2015 01:40 pm
Possible blown head gasket??? Shyneharder General PT Cruiser Discussions 6 30 Oct 2011 04:00 pm
WARPED HEAD / SCORED CAMSHAFT / BLOWN HEAD GASKET amadeo Tech & Performance Forum 5 12 Apr 2011 01:03 am
Blown head gasket fatboypt Tech & Performance Forum 2 14 Nov 2010 09:57 am
