shifter cables
Old 28 May 2012, 05:20 pm
Default shifter cables
I just bought my 01 pt cruizer a few weeks ago and seem to keep grinding second unless i push in the clutch and give it a couple seconds before i shift.I've also, noticed sometimes I shift it into reverse it doesn't catch sometimes as well as the shifter feels vague.From what i've read it sounds like the shifter cables,but the place I bought it from said the cables on the transmission side are tight.Can anyone confirm my diagnosis and since my local stealership is closed today does anyone know the cost of them???
Old 28 May 2012, 08:43 pm
UptownSport's Avatar
Default Re: shifter cables
No one replaces shifter cables except the dealer- They only break in extreme conditions-
Such as powershifting during drag racing.
Even then you just thread on a metal end.
First; I'd get some 'Booger Bushings' (They're $20- 25 Shipped) and install-
It'll shift like a dream
Then search for the clutch adjustment-
Chromenut (see links in my signature) has a booger bushing install how-to, AND he might be able to give you a 'line' on a manual to help with your clutch adjustment.
Old 28 May 2012, 10:27 pm
I tried looking for a how to on here and youtube.I saw one for a neon,but was wondering how to pull the console off of the shifter area???
Old 28 May 2012, 11:09 pm
Ones under console last much longer- If not forever- Large one (on trans shift arms) constantly fails
Here's trans end how-to from Chrome:
Shifting Problems
I took console off; don't recall anything remarkable about procedure
reverse cables ape_stein Tech & Performance Forum 1 26 Sep 2010 11:45 pm
01 PT / Touring - manual transmission shifter cables fianafail Tech & Performance Forum 2 17 Sep 2010 08:32 am
need 2001 replacement shifter cables fianafail General PT Cruiser Discussions 0 17 Sep 2010 05:21 am
Battery Cables and terminals 2002ptcruiserwoody723 Tech & Performance Forum 8 07 Nov 2009 10:24 am
New coil and spark cables. PTBoricua Tech & Performance Forum 6 20 Oct 2009 10:37 pm
