My 05 pt cruiser fan does not turn on with A/C.
Old 29 May 2012, 01:10 am
Default My 05 pt cruiser fan does not turn on with A/C.
Hello !
So my fan does not turn on when I engage my A/C, I have done the troubleshooting techniques as i found on this site. I hot wired the fan motor and it turned on therefore the motor is good. I have replaced the High speed relay and the low speed relay and the A/C relay in the engine fuse box. The glass top fuse (40A) is also in good condition. The system has been recently charged so it ca not be due to low freon. Im now pretty stumped!
Old 29 May 2012, 02:54 am
Default Re: My 05 pt cruiser fan does not turn on with A/C.
Originally Posted by JonS View Post
I have done the troubleshooting techniques as i found on this site. I hot wired the fan motor and it turned on therefore the motor is good. !
Did you get both the low speed and the high speed t come on while testing?
Old 29 May 2012, 03:09 pm
When I applied direct power on the fan connector the left pin would not activate it only the right one. I am quite unsure if it is the high speed but it did sound pretty loud. What does this mean?..thanks crewzin your the best!
Old 29 May 2012, 03:18 pm
cruserdad1976's Avatar
cantn say what it is but from all i have read when mine went south i just ordered a NEw fan off ebay put it in and all was good im not real big on changing relays ebay has them for $89 and the one i put in has worked great
Old 29 May 2012, 03:28 pm
JonS, both speeds of the fan should be able to activate while putting 12V to either pin. If it sounded pretty loud, then the low speed ins't working.
Old 29 May 2012, 04:12 pm
So at this point should I just replace the fan motor? I know that autozone sells it for about $100... how complicated is it? Is there any links that show a step by step process? Thank you very much for the help!
Old 29 May 2012, 04:24 pm
There just happens to be a HOW TO on that fan housing...
Removing the fan and housing 01-05 PT
OR, if you have the time, you can try and fix the fan motor yourself...
http://www.ptcruiserlinks.com/forum/...-fan-motor.jpg
Old 29 May 2012, 09:59 pm
mdfrodolives's Avatar
Jons, just get the whole fan. It costs about the same as the motor (really!), and will save you time. RockAuto has a Dorman one for cheap and it's guarranteed for life.
Tim
Old 30 May 2012, 05:23 pm
i had the same issue with mine earlier...i replaced the relay on the front by the fan....when looking in its the one to the left.....just my 2 cents
Old 08 Jun 2012, 06:51 am
Ok so i finally bought the whole fan for about $80 installed it as crewzin's link showed me and now my A/C is in perfect working order. thanks for all the suggestions.
Windshield Wipers Turn On With Turn Signal or Bump... NewPTCruiserInPA General PT Cruiser Discussions 8 17 Dec 2013 09:10 am
Read this if your Cruiser won't turn over... fgbrender Tech & Performance Forum 4 23 Dec 2010 04:25 pm
2008 PT CRUISER WHEN THE AIRBAG IS DEPLOYED DOES THE ENGINE TURN OFF? ilk42 Tech & Performance Forum 1 28 Jun 2010 09:20 pm
dome light doens't turn off till i turn on the car... realized Interior Accessories Forum 3 15 Jul 2009 06:44 pm
blue turn signal bulbs that turn orange when in us Capt Kidd General PT Cruiser Discussions 1 04 Jun 2004 10:10 pm
