02 Not Starting
Old 29 May 2012, 11:12 am
Arrow 02 Not Starting
Where to start....The engine shut itself off while going down the road cause it got hot. We have changed the head gasket, timing belt, water pump, belt tensioner, and while it was off changed the spark plugs. It started fine after that but noticed a stream of water. Checked and the bottom post of the radiator had broke. So now it has a new radiator. Started up and ran fine. Let it run for about 15 minutes and it started overheating. I checked the fan and now only one side of the connector (only one speed) works when hard wired. All relays have been checked and are working. It will not start back at this time.
Old 29 May 2012, 11:35 am
Default Re: 02 Not Starting
Any codes ? I'd check the Crank Sensor...Check Fuel Pump Pressure....
Old 29 May 2012, 11:56 am
No codes ever show up. Is there a way to check the cam and crank sensors?
Old 29 May 2012, 12:08 pm
There's no way to check those sensors but they should throw a code if they are bad. Start off by changing the fan out since you only have one speed but that won't stop it from starting. You have a Schroeder valve at the end of the fuel line at the front of the car. You need to put a pressure gauge on it to see if your fuel pump is working and check for good spark. That's the two main things to make the car run.
Old 29 May 2012, 06:27 pm
The fuel pressure was 59 psi. What is normal compression supposed to be?
Old 29 May 2012, 06:46 pm
It's PRESSURE not compression and should be between 53 and 63, so your good.
Old 29 May 2012, 07:39 pm
I meant what is normal engine compression?
Old 29 May 2012, 07:59 pm
170 to 225 psi with a 25% maximum variation between cylinders. Make your questions a bit more concise.
Hard Starting GT prighello General Turbo Discussions 7 17 May 2011 09:43 pm
Looking for starting help bluesanity General PT Cruiser Discussions 3 20 Mar 2010 12:16 pm
'03 Not starting GunnerIke Tech & Performance Forum 6 29 Oct 2009 09:55 am
Pt Cruiser Not Starting teknoron Tech & Performance Forum 8 11 Sep 2008 02:04 pm
Just Starting air4cefamily General PT Cruiser Discussions 3 29 Mar 2008 08:41 pm
