Engine shudder with ac and heater
Old 29 May 2012, 07:37 pm
Question Engine shudder with ac and heater
My 2003 cruiser engine has developed a very noticeable shudder when I turn on the ac or the heater. It is much more noticeable with the ac though. Any thoughts on where to start troubleshooting it? Runs good otherwise, just when I switch one or the other on. And thanks!
Old 29 May 2012, 07:44 pm
Default Re: Engine shudder with ac and heater
I'm not sure why it would shudder when the heater is on, but if it shudders when the A/C is on, it is more than likely the radiator fan. Turn the A/C on, and check the radiator fan to see if it comes on. If not, then it's time for a new fan, or to try to fix the fan. There are numerous posts on this forum for you to check out related to this issue.
Old 29 May 2012, 09:56 pm
mdfrodolives's Avatar
Do you mean your A/C and "defrost" (in heater mode)? If that's the case, it sounds like your fan is shot--if this 'Shudder" occurs at idle, only. Your A/C vents will also blow warm at idle, but will blow cool again when you resume speed.
Our radiator fans also cool the "high side" of our A/C systems, via the A/C condenser. No fan cooling--or too little--and the pressure builds up, putting too much strain on the engine at idle. Thus, the "shudder".
Tim
shudder and sputter when in 4th gear pppt03turbo General Turbo Discussions 2 25 May 2012 08:35 pm
Cold start shudder ptguy69 Tech & Performance Forum 4 20 Jun 2011 11:14 pm
Light Shudder On Acceleration bob2006 Tech & Performance Forum 18 21 Dec 2010 03:30 pm
Block Heater, Rad Hose Heater, Which?? kb0nly Tech & Performance Forum 13 23 Dec 2008 03:47 pm
engine block heater SteelBlueGT General PT Cruiser Discussions 4 25 Oct 2002 06:33 pm
