Codes 1193 & 1297
Old 01 Jun 2012, 03:52 pm
Question Codes 1193 & 1297
02 PT Cruiser has codes 1193 & 1297 on the code reader. What are those codes and how do I fix them?
Old 01 Jun 2012, 05:57 pm
UptownSport's Avatar
Default Re: Codes 1193 & 1297
From '01 FSM:
P01193 Inlet Air Sensor input above acceptable voltage
P01297 No Change in MAP From Start to Run
I'd *Guess* you need two new sensors.
I don't even know if the PT uses an integral AIT/MAP sensor- so it could be just one sensor!
Someone just ran into the 1297 recently, I believe replacing with a Mopar sensor solved it. Using a Standard brought the same code ...
Standard now has "T" series, I don't think those are the mechanic's 'old trusty's' anymore.
In any case, search- probably a start to fix story on here
Old 01 Jun 2012, 06:00 pm
P1193 indicates a circuit voltage is high at the IAT sensor. That's the one that measures the incoming air.
P1297 (M) - No change in MAP from start to run. No difference is recognized between the MAP reading at engine idle and the stored barometric pressure reading.
Understand that a Diagnostic Trouble Code (DTC) indicates that the Powertrain Control Module (PCM) has recognized an abnormal condition in the system. DTC's are the results of a system or circuit failure, but do not directly identify the failed component or components.
If the MAP sensor is faulty an individual with average DIY skills can handle the replacement procedure.
2001 PT Cruiser Error Codes 1193 and 0320 01cruiserproblem Tech & Performance Forum 0 06 Jun 2011 06:34 pm
troubleshooting help codes 340/1193 jbptcruzn Tech & Performance Forum 6 04 Jun 2011 11:29 pm
Oh no, multi codes = valve problems? (123, 300, 302, 303, 351, 352, 1193) Chicago_gal Tech & Performance Forum 8 28 Oct 2009 11:11 am
error codes 0351 0352 1193 partyd General PT Cruiser Discussions 8 29 Aug 2009 03:21 pm
Code # 1193 1lowufo Tech & Performance Forum 5 31 Aug 2004 11:29 pm
