Lower Motor Mount
Old 03 Jun 2012, 11:35 am
Default Lower Motor Mount
recentllay ordered some BWoody motor mounts and was just lookin for some tips on replacing the lower one
Old 03 Jun 2012, 11:50 am
03GTCruiser's Avatar
Default Re: Lower Motor Mount
Mine was pretty simple. Just have to remove the plastic shield that's down there (mine was already removed by some road debris) and just unbolt stock and replace with bwoody.
I'm too big to get under there stop had it done by one of my local srt guys. Took all of 20 minutes to change upper and lower motor mounts.
Sold 2003 Pt Cruiser GT Autostick. Sold
Now a slow 2009 Pontiac vibe 2.4l 5-speed.
http://www.ptcruiserlinks.com/forum/image.php?type=sigpic&userid=9656&dateline=1247691  818
227 HP and 281 TQ
new best of 14.56 1/4 mile on 7/25/12 still using the canned tune from my diablosport predator.
*Stage 1, DSP w/93 canned tune, 3" o2 housing, 3" FWDPerformance downpipe with cutout. Bwoody solid mounts. AMX1397 TTAB with K&n drop in filter and airbox mod. AMX1397 lower pipe and AMX1397 uppipe with HKS BOV
* stock nsrt rims powdercoated black, chrome pillars.
* 3 gauge pod w/ aem wideband, Autometer ultralite oil pressure and 30/30 boost, Mopar 8" sub.*
Old 03 Jun 2012, 11:52 am
Also may want to use a jack under the motor to keep it from shifting if you still have stock upper.
227 HP and 281 TQ
Old 03 Jun 2012, 09:09 pm
Awesome, i see you have them to did you see a difference, I heard solid mounts give alot of noise into the cabin aswell
Old 03 Jun 2012, 09:42 pm
808's Avatar
808 808 is offline
Do a search under this part of the forum. There is a precise measurement that must be made before tightening/torqueing the upper and lower mounts.
Old 03 Jun 2012, 09:46 pm
808's Avatar
808 808 is offline
Changed Motor Mounts Engine Shakes
Old 03 Jun 2012, 11:05 pm
I never did any measuring, but had no problems with having to move the motor for any of this. We just unbolted the upper and installed the dog bone, then did same with lower.
I do have more vibration than I did before, but that was to be expected. More vibrations with a/c on.
Do hear some sound transfer with a/c on, but again, to be expected.
227 HP and 281 TQ
Old 04 Jun 2012, 09:20 pm
hell i get that with the stock mounts, i dont even wanna know what these sound like after. let you guys know how it goes this weekend when I put them on
Old 05 Jun 2012, 09:26 pm
Kawizx9r's Avatar
10 minute job; no way you can mess things up. Searches yield results.
If you went with inserts, solid mounts, or anything stiffer expect more noise as well as vibration. Won't be as apparent though if you drive a manual; I would recommend soft-inserts or polyurethane-fill if equipped with an automatic.
Kawi is a friggin genius!
How to replace lower motor mount apalomo01 Tech & Performance Forum 17 20 Jul 2014 05:36 pm
Tie-rod and lower motor mount just in time for road trip Dino General PT Cruiser Discussions 3 24 May 2012 07:35 pm
Lower Engine Mount Q yuanbao Tech & Performance Forum 8 09 Dec 2011 10:14 am
Lower motor mount bolt specs (missing bolts) joe504 Tech & Performance Forum 2 17 Sep 2011 05:28 pm
Lower engine mount ejacko Tech & Performance Forum 5 21 Mar 2009 12:01 pm
