# 1 missfire
Old 03 Jun 2012, 12:06 pm
Default # 1 missfire
I have 70000 miles on my 07 around 30000 mile's I had a similar problem with # 1 misfire new plug's and wire's did the trick run fine until now it misfire's at idle I replace plug's and wire's and run seafoam spray through the throttle body still misses could this be a stuck or burnt valve? I have extented warranty I will be taking it to a dealer Tuesday or Wednesday just thought I would run it past you all and see if anyone know's what this could be Thank you all in advance for any help you could give me!!
Old 03 Jun 2012, 12:13 pm
Default Re: # 1 missfire
There are so many things that could cause a misfire in one of the cylinders, it won't do you any good to just throw a few guesses at you unless you would want to try things to fix it. Since it's going to the dealer, hopefully they will find the fault and fix it under warranty.
Old 03 Jun 2012, 10:43 pm
mdfrodolives's Avatar
And be so kind as to reply to this thread and tell us what the problem was.
Tim
Old 03 Jun 2012, 10:44 pm
If you are experiencing a true misfire then your car will be posting an error code. Do the key dance and see if it pulls up any codes!
Crazy missfire ! ptTurbo528 Tech & Performance Forum 7 24 Jan 2013 10:32 am
missfire 20lt pt cruiser waftyrob Tech & Performance Forum 4 20 Nov 2011 02:33 pm
05 pt intermitant missfire bobrat Tech & Performance Forum 3 19 Aug 2011 10:10 pm
Terrible missfire? allhale09 Tech & Performance Forum 8 12 Apr 2009 09:24 pm
Missfire & backfires Turbo Red General Turbo Discussions 6 18 Oct 2004 07:58 pm
