Replacing PCM - 2002 PT
Old 03 Jun 2012, 03:06 pm
Default Replacing PCM - 2002 PT
Hi everyone!
After replacing cam shaft/crankshaft sensor and magnet, my PT is still giving codes 0320, 0340, and 1391. Having had a lot of help here on the forum in trying to diagnose the problem, I'm thinking the PCM may be the problem.
So I located a PCM on Craigslist. I was told that I would also have to replace the key and lock from the same PT. Does anyone know if this is correct? Thanks!
Old 05 Jun 2012, 10:39 am
Default Re: Replacing PCM - 2002 PT
Never heard of that, but the PCM will have to be programmed with your car's VIN# - usually at a dealer.
Is PCM you got from same year?
Old 06 Jun 2012, 07:39 am
Hi,
Thanks for your reply. The PCM is from a 2002 - found it on Craigslist pretty cheap. When we installed it, there was a code that came up that basically said the key did not match the PCM and the same guy has the key and lock. That's the reason for my asking.
There's someone on EBAY selling PCMs for under $200, and I believe it's as you said, he programs in the VIN. I'm going to check that out as we've had a very bad experience with the local dealer doing over $400 of unauthorized work they which had been done the week prior, and which didn't fix the problem. We really don't want to deal with them if we can avoid it.
replacing TCM Bentron General PT Cruiser Discussions 15 19 Jun 2011 03:17 pm
2002 PT Need Help - Replacing "Ball Joint Bushing"? Pied397 Wheels, Tires, Suspension 0 17 May 2010 11:12 am
replacing Cat omaolain General PT Cruiser Discussions 7 05 May 2010 08:27 pm
Some questions on replacing a coil in a 2002 PT Cruiser mbellofatto Tech & Performance Forum 4 25 Mar 2009 07:44 am
replacing oil filter only boosta General Turbo Discussions 20 04 Aug 2003 10:14 pm
