timing marks HELP
Old 05 Jun 2012, 04:31 pm
Default timing marks HELP
i replaced the water pump and belt on my 01 2.4 cruiser .Problem is i can't get the timing marks to line up. I have the motor jacked up but it is on a angle and can't seem to line them up i did read the other treads on this topic but got no info on this prob.
Thankx Pete
Old 05 Jun 2012, 05:01 pm
fabreezai's Avatar
Default Re: timing marks HELP
Pete-
When you replace the belt, with the timing marks on the cams lined up with the arrows up (tdc) the timing mark on the crank should be just on the edge of the tooth where the timing mark is on it. In other words the cam marks will be lined up on the cams but the crank mark will be about a half tooth off (I think it's on the trailing edge). Make sure you turn the crank by hand 4 times when you re-check it or you can be 180* out. Hope it helps. Let us know.
Cheers! 2003 2.4, N/A, Touring, Supercharged, 5 speed. 126k..... Blew up that engine, building another to take the boost! Built a new engine, still working out some issuess.......
Old 05 Jun 2012, 07:21 pm
does all 4 of timing marks line up?
Old 05 Jun 2012, 10:28 pm
UptownSport's Avatar
focus only on bolt centers and center marks
Old 06 Jun 2012, 01:54 pm
Ok thankx again i am gonna giv it another shot
Old 06 Jun 2012, 04:14 pm
just did this on Neon, it 1000 times EZier than PT (same engine for our purposes) and it still kinda sucks to see
Timing Marks (Pics) DigitaL101 Tech & Performance Forum 30 29 Nov 2014 10:27 pm
Timing marks... loadedchainsaw Tech & Performance Forum 2 29 Mar 2011 08:31 am
timing marks luko Tech & Performance Forum 0 18 Sep 2010 06:12 pm
2003 Timing Marks rhowle Tech & Performance Forum 2 07 Sep 2010 10:41 am
Quick Question about Timing Marks Jimrea Tech & Performance Forum 1 03 Jul 2010 04:34 pm
