Check Engine Code P0601 PCM internal malfunction
Old 06 Jun 2012, 04:03 pm
Default Check Engine Code P0601 PCM internal malfunction
Check Engine light came on. Had it checked and it came back to this code. The funny thing is, it is running better now with the check engine code than before it came on. It use to run rough and sometimes wanted to stall when you first started away from a stop. It is a standard transmission. We did have some battery problems a couple of weeks ago. Don't know if this has anything to do with it.
Old 06 Jun 2012, 04:05 pm
Default Re: Check Engine Code P0601 PCM internal malfunction
Battery problems might have set off the code so it might be a false alarm. For now, take the negative battery cable off for about 5 minutes. Step on the brake pedal to get rid of any built up charge. Put it all back together and see if it clears the code.
Check Engine light code help sohc1996 Tech & Performance Forum 8 30 Sep 2012 07:36 pm
Check engine code p0340 SaphireRain Tech & Performance Forum 21 26 Apr 2012 12:58 pm
Check engine light on - can't get code Pinkbadge Tech & Performance Forum 5 10 Apr 2011 07:01 pm
HELP! Check Engine Code PTridinclean Tech & Performance Forum 6 22 Sep 2009 12:28 pm
CODE P0141?? CHECK ENGINE MEXICANPT General Turbo Discussions 0 08 Aug 2003 02:03 pm
