Why does my PT's throttle body need replacing?
Old 06 Jun 2012, 04:24 pm
Exclamation Why does my PT's throttle body need replacing?
Hello everyone firstly I just want to say a big thank you to all you wise PT owners who have been advising us newbe's as I have benefited from your knowledge on here, so here I am to ask if you have an answer to my dilemma. My PT is a 2.0 51 plate and has just had a large amount of work and gen maintenance done, i.e belt, water pump, thermos, head gasket, radiator, and so on. Since the work has been done she vibrates a bit too much and has a v.bad idle therefore simply cuts out each time I am stationary, the mechanic says I have a faulty throttle body & I should replace it togehter with the inlet manifold. Before he told me this I read on here that it would be a good idea to clean it first which he said he has done (I also put in a bottle of CATACLEAN), so my question is what is the actual fault with the throttle body and was it caused because the head gasket was damaged?
http://1.2.3.9/bmi/www.ptcruiserlink...s/confused.gif
Please advise guys
Thanks
Old 06 Jun 2012, 04:38 pm
Default Re: Why does my PT's throttle body need replacing?
Never heard of ANYONE having a faulty throttle body. Maybe one that needs cleaning but not bad enough to throw it away and replace it.
Was you large amount of work (which included the timing belt) just recently done before the vibration and bad idle and cutting out? If so, it sounds like the classic symptoms of the timing being off because the mechanic didn't get it right.
Sounds like you'll have a hard time proving it to him but we've seem all those conditions before and it came out to be right after the timing belt change and when done over and done right, everything cleared up.
Old 06 Jun 2012, 05:15 pm
mdfrodolives's Avatar
Does the engine vibrate only at idle? How does it run when you're on the road?
By the way, you need another mechanic. That throttle body story he gave you is way off the charts.
Tim
Old 06 Jun 2012, 08:12 pm
UptownSport's Avatar
Agree with previous- Obviously anything on a car can fail, but have never heard of a modern TB failing; they use bearings instead of bushings, so it doesn't wear like carbs did.
Perhaps he means IAC?
If I understand correctly- I'd also agree timing is off
Old 07 Jun 2012, 02:29 am
Me 2, joining the gang above. I've seen plenty of completely dirty throttle bodies that needed real cleaning up, but never seen one that needed replaced. One thing to note too is that you should check on the throttle cables - I put a bit of WD-40 down a friend's after we did her throttle body and boy did it change the throttle response!
Old 07 Jun 2012, 08:23 am
Me 3, what they said!
Old 07 Jun 2012, 12:54 pm
i have broken the shaft of a throttle body in half when i had a 250 shot of nitrous backfire in my mustang. it also blew ALL the vacuum lines off. heh. it was pretty spectacular.
Old 08 Jun 2012, 07:22 pm
X4 Timing is off. I've NEVER heard of one of our throttle bodies going bad.
Jerry
Old 09 Jun 2012, 12:24 am
wheelgarage's Avatar
X5....
Buy new seals, pull off the TB, take it apart and clean it with the correct cleaner, put it back together....like new!
2005 Touring Black - Automagic....California Smog Legal
H&R Cup Kit | TSW Sakata 18x8 35ET | Nankang NS-II 235/40/18 | SPC front alignment cam - rear shim | Master Pro Rotors | Master Pro Ceramic F/R pads | Rebuilt Cylinder Head - Safety Valves and Guides | Felpro Head Gasket and upper rebuild kit | Fail-safe 195 degree thermostat | Mopar Waterpump...lol | 3rd radiator fan motor | Gates timing belt kit | WIX filters (oil, transmission) | Mobile 1 5w30 | Mopar ATF4 | Redline Water Wetter | K&N Drop-In | 4th Drive side Axle | Energy Suspension Torque Mounts | 3rd set of Torque Mounts...
Tags
idle, inlet manifold, throttle body, vibrates
Throttle Body Jimmy2011 Turbo Performance 4 27 May 2012 06:29 pm
Larger Throttle Body? My02RedRide Tech & Performance Forum 17 05 Aug 2011 02:21 pm
EGR and Throttle body pteezer129 Tech & Performance Forum 5 22 Jul 2011 02:28 pm
Throttle Body wiky86 Tech & Performance Forum 10 21 Jul 2008 09:59 pm
looking for a throttle body....................... rockrtboy Classifieds: Want To Buy 2 09 Jun 2007 11:44 am
