Lower engine mount recomendation...?
Old 07 Jun 2012, 09:03 am
Default Lower engine mount recomendation...?
I have to replace my lower engine mount (shocker!), should I consider using an after market solid type mount, or should I just put another OEM mount on there? Pros - cons? Experiences? Thx.
Old 07 Jun 2012, 11:09 am
Default Re: Lower engine mount recomendation...?
I replaced it with a stock one, I heard to many people complain about vibrations.
Old 07 Jun 2012, 11:48 am
UptownSport's Avatar
My strong suggestion is to use 3m Windshield Urethane, it's a 'forever' fix
Old 07 Jun 2012, 12:08 pm
How's that work? I think I know where you are going with this suggestion....
Old 07 Jun 2012, 12:40 pm
you can fill the mounts with 3m window weld, but it's $25 and it takes two full days to dry.
for $15 you can buy this from vatozone and get the same result:
Transmission Mount - Performance | 2001 Chrysler PT Cruiser 4 Cylinders B 2.4L SFI DOHC | AutoZone.com
i filled mine with the 3m and that is what i'd recommend if you have the ability to let it sit and thoroughly dry for a couple days.
Old 07 Jun 2012, 02:19 pm
Why do you recommend the $25 window weld over the $15 part that is made for this?
Old 07 Jun 2012, 02:49 pm
Urethane will fix the broken mount, and is forever.
Inserts, not so much.
It was about $12 per tube when I bought, here's google search for prices:
Main mounts on my Neon were broke and filled before they even made your PT- They're still perfect today.
It does take a while to dry, (without your wife's knowledge) stick it in oven on warm- it'll only take a few hours to dry.
Old 07 Jun 2012, 07:56 pm
mdfrodolives's Avatar
I got "Duralast" from Autozone, and they're warranteed forever. That's been over 30,000 miles and I was looking in the area the other day, and the strut still looks like it was just put in. The steering wheel is a little stiffer at idle (my wife says, although I don't feel it), but maybe that's why the thing is not deteriorating like the OEM strut that came with the car.
Or, you can do the 3M trick.
Tim
Old 07 Jun 2012, 08:18 pm
I just picked up a new lower mount, it has a bunch more rubber in there then the stock one I took out. I don't think it would take much urethane to fill in the rest. The time isn't an issue because my PT is not on the road yet. With all the stuff I am findimg broken on this thing, it might be a while.
Old 09 Jun 2012, 11:37 am
Here's why not bushing inserts:
Originally Posted by wheelgarage View Post
That was the ISSUE!!!
It was the lower mount, under the A/C. The Energy bushing insert strap broke and the constant pressure from the rear insert helped the bolt back off. I cant really tell, but it looks like the main pulley or the A/C pulley rubbed against the frame. All belts look good...
Check the tranny fluid level and topped it off. Then...took it for a romp (with my wife in the passenger seat).
All is back to normal!
How to replace lower motor mount apalomo01 Tech & Performance Forum 17 20 Jul 2014 05:36 pm
Lower Motor Mount LooseJox Tech & Performance Forum 8 05 Jun 2012 09:26 pm
Tie-rod and lower motor mount just in time for road trip Dino General PT Cruiser Discussions 3 24 May 2012 07:35 pm
Lower Engine Mount Q yuanbao Tech & Performance Forum 8 09 Dec 2011 10:14 am
Lower engine mount ejacko Tech & Performance Forum 5 21 Mar 2009 12:01 pm
