Rev Problem *Help please*
Old 07 Jun 2012, 02:06 pm
Default Rev Problem *Help please*
Today when i went to start up my pt cruiser [Hasn't been run in a while] i revved it a couple times while i was in park. Is it bad to do that? The highest rev i got to was about 3500-4000 and it lurched a little bit. after that the revs dropped to about 700 then the engine brought it back up, is this normal?
BTW i have a 2001 limited editon pt. if that helps.
Old 07 Jun 2012, 02:12 pm
Default Re: Rev Problem *Help please*
that's normal. the idle air control closes to help the rpm's come down. once the rpm's are too low the IAC lets more air in and it comes back up (:
Old 07 Jun 2012, 02:24 pm
Cool thanks, i was worried that i revved it to high and something broke.
Old 07 Jun 2012, 02:42 pm
UptownSport's Avatar
Due to magnificent Chrysler shifters, several of us have selected incorrect gears while racing- I'd guess mine hit 10,000 RPM- Only clutch broke.
Other's have had valves float & bend (2.0) (Clutch, too of course).
My brother regularly revs his 2.0 to 8500 just to PO me
Old 08 Jun 2012, 07:17 pm
You simply hit the factory "park/neutral' rev limiter. Every PT has it. It will do this every time you rev it to those levels while in park/neutral to keep us from free-wheeling our engines to death.
Jerry
So, is my FAN the problem!? kcpope General PT Cruiser Discussions 38 11 Aug 2012 07:38 pm
is it a balljoint problem or a wheel bearing problem? phtech Tech & Performance Forum 2 05 Mar 2011 04:33 pm
A/C problem bjagd02 General PT Cruiser Discussions 4 26 May 2010 07:11 pm
MPG problem morrises Tech & Performance Forum 8 09 Jul 2008 06:49 pm
Anyone have this problem? PTGT Redman Tech & Performance Forum 4 26 Mar 2004 11:08 pm
