rad fan question
Old 07 Jun 2012, 08:30 pm
Crid's Avatar
Default rad fan question
I have an 06 n/a and just replaced my rad fan. And that's all said and done. But I had to drain the rad obvs. And I filled it back up. And let it get to operating temp. And now its runs on the hot side of normal. And when I have the heat on it doesn't blow any hot air. Do I have a heater core lock? And if so how do I fix it. And help would b great!
2006 Cruiser, Non-Turbo, 19 inch Konig Trouble rims on 225/35/19 Ironman Imove tires, Airaid CAI, E3 Plugs, msd super conductor 8.5 mm wires, Freedon Design Strut Tower Brace, Glow Shift Pillar gauges, EBC Slotted Rotors with EBC Green Stuff Ceramic Fiber Core Pads, Lowerd on Tien springs, Full Custom Kenwood Excelon sound system with 1 12" JL Audio W0, 8000k Blue hids up top and aftermarket OEM Fogs with white 8000k in bumper. Ipcw Bermuda black true led taillights with tinted reverse lights.
Old 07 Jun 2012, 08:49 pm
Default Re: rad fan question
Did you bleed the air with the bleeder on the t-stat housing?
First, you didn't have to drain the radiator to put the fan in but that's a moot point now since you already did it. Second, it sounds like you didn't get everything filled up and you have air trapped in the coolant system. That will cause you to run hot and stop the heater from blowing hot air.
Busted ....you beat me to it.
Old 07 Jun 2012, 08:52 pm
Crid's Avatar
No I didn't bleed anything, how do I bleed the air our to fix my air lock and cold heat prob. I also need to get some more coolant
Old 07 Jun 2012, 09:04 pm
See if this helps.
Bleeding air from cooling system
Old 07 Jun 2012, 09:09 pm
Crid's Avatar
I'm sure that will do the trick. Could I also run the car with the heat on and rad cap off and keep adding fluid? Till it stops bubbling?
Old 07 Jun 2012, 09:22 pm
Never tried it that way. How does that get the air out?
Old 08 Jun 2012, 05:15 pm
That's one way to do it. But just be VERY careful, since the coolant can bubble over or shoot out at any time. I use a very large funnel and push it securely into the radiator opening when I do this so that if the coolant expands and needs to get pushed into the reseervoir tank, it fills up the funnel instead of bubbling over onto the engine.
They also make a special funnel for bleeding the cooling system, but I've never seen them sold in stores, only on the internet.
Old 08 Jun 2012, 05:37 pm
i think every time you take off the cap you introduce air into the system. Keep the cap on and add fluid to the overflow tank and check it that way. It should bleed the air out after few hot/cold cycles
'03 GT base w/175k and a 2 speed autostick (read: trans is shot) and powered by a hybrid MOPAR S3 with DSP untuned
1st Forward Motion E1 powered PTGT w/Psi-Fi Power pack fuel tuner back in '07
FS: '03 GT Elec Blue w/rear suicide doors or '03 auto PCM, S3 turbofold, WGA, 3.5" o2 & 3" DP - make offer
Old 08 Jun 2012, 07:49 pm
mdfrodolives's Avatar
Why not just turn the bleed screw, like you're supposed to. It does a great job. Also, before bleeding, makes sure your heater control is turned to full HOT. And it's a good idea to attach a clear hose to the nipple of the bleeder screw--about three feet long--and attach the other end of the hose to a catch can. This keeps the coolant off your belts, which will squeak if you don't do it this way.
It's not that difficult--except your (I think it's 10mm wrench has to be a shorty to get into the area at the base of the thermostat housing).
Have fun.
Tim
:question:daytime running lights!!!:question: jrs61282 Tech & Performance Forum 10 07 Nov 2010 10:53 pm
Luggage Rack question and trailer hitch question Patrick_Dickey General PT Cruiser Discussions 5 26 Apr 2009 09:19 pm
