HELP
Old 08 Jun 2012, 04:26 pm
Angry HELP
I BOUGHT THE REPAIR MANUAL FOR MY PT I BEEN ON THE WEB 4 2 DAYS AND CALLED SEVERAL LOCAL DEALERS AND MECHANICS AND STILL CAN NOT FIND THE FUEL RELAY SWITCH OR FUSE. NOT IN THE BLACK BOX BEHIND THE AIR FILTER LIKE EVERYONE SAYS. THERE ARE TWO ON THE FIRE WALL DRIVERS SIDE AND 2 BY THE FAN(ONE IS FOR THE FAN)HELP ME PLEEEZ
Old 08 Jun 2012, 06:11 pm
Default Re: HELP
First off, what year PT? And are you talking about the fuel pump relay?
Pre-2006 PTs have the relay in the fuse box. There's a diagram in the fuse box lid showing the location.
2006-2010 PTs do not have a fuel pump relay.
-Chris
Old 08 Jun 2012, 06:24 pm
Default Re: HELP
It would appear to be a 2006 based on his site name.
Old 09 Jun 2012, 03:37 pm
Angry Re: HELP
yes i am talking about my 2006 hence the name. just bought a fuel pump realy from autozone. here is what it is doing when you turn the key it cranks but wont start. can not hear fuel pump kicking on. we just replaced the radiator(big pain in***)now stupid thing is wont start. battery fully charged. check engine light on turns over but.....not him her. did the key dance no codes just done. found the pic of my fuse box on crewzins thread from sept. asked replacing the whole thing?
Old 09 Jun 2012, 04:18 pm
Default Re: HELP
Your working two threads at one time. Please don't do that. You get people answering on both threads not knowing what the other has said. I'll be deleting the other thread.
Old 09 Jun 2012, 04:46 pm
Default Re: HELP
sorry
Old 09 Jun 2012, 05:36 pm
Default Re: HELP
Check that you didn't leave some wires loose.
Old 09 Jun 2012, 06:50 pm
UptownSport's Avatar
Default Re: HELP
Odd.
Could you see if fuel pump starts momentarily immediately after key is turn to start/run??
If PCM doesn't get crank signal it'll disable fuel pump.
As Busted said, a ground wire may have been left off or disturbed.
Old 09 Jun 2012, 06:57 pm
Default Re: HELP
If you disconnected the coil pack for some reason, make sure you reconnected it. I forgot that step one time and couldn't get the car started. I was happy when I realized that was what the issue was.
Old 11 Jun 2012, 05:43 pm
Default Re: HELP
Your 2006 PT does not have a fuel pump relay. As stated, make sure all the wires and connections are tight and proper.
-Chris
