Grinding - Accelerating from a stop
Old 08 Jun 2012, 04:35 pm
wheelgarage's Avatar
Default Grinding - Accelerating from a stop
I finished up the install of the driver side axle. I topped off the transmission, then I took it out for a romp, all good, no noises.
I get home and check the fluid level, just needed a 10th..
Wash up and got ready to leave with my wife. We drive off and there is that grinding sound from the passenger side. It only occurs from a dead stop to acceleration, then goes away. It definitely sounds like a bad bearing that rumbles under load.
Okay..today is here...
I put the car on jacks and began my inspection. In park, I check to see if there is any odd play. Nothing...nothing between the axle and transmission, and nothing between the axle and hub. I then inspected the hub bearing, check for any side by side play, up and down....nothing. I put the transmission in neutral and began the same process, but in addition, I spun the wheel hear for any noise....nothing. So, I pulled out the stethoscope to listen even closer....almost nothing. I can hear a little weep from the hub, but no grinds!!! I then turned to the transmission listened for anything...nothing!!!
So, I pulled out the passenger side axle took it apart. All the bearings are in good shape, I see no shaving or anything out of place. I guess I should clean off all the grease and take it FULLY apart.....ugggg.
2005 Touring Black - Automagic....California Smog Legal
H&R Cup Kit | TSW Sakata 18x8 35ET | Nankang NS-II 235/40/18 | SPC front alignment cam - rear shim | Master Pro Rotors | Master Pro Ceramic F/R pads | Rebuilt Cylinder Head - Safety Valves and Guides | Felpro Head Gasket and upper rebuild kit | Fail-safe 195 degree thermostat | Mopar Waterpump...lol | 3rd radiator fan motor | Gates timing belt kit | WIX filters (oil, transmission) | Mobile 1 5w30 | Mopar ATF4 | Redline Water Wetter | K&N Drop-In | 4th Drive side Axle | Energy Suspension Torque Mounts | 3rd set of Torque Mounts...
Old 08 Jun 2012, 04:38 pm
Default Re: Grinding - Accelerating from a stop
Too add....this happened only when my wife was in the passenger side. So, that tells me if there is more load then something is definitely slipping, by some means.
Could it be the diff bearing or even the diff itself!?!?!?
Old 08 Jun 2012, 05:00 pm
Okay...more questions...if the diff is going out, wouldn't it just chatter?.....(grasping at straws at the moment)...
Old 08 Jun 2012, 06:50 pm
If I were you I'd check the upper and lower torque struts, just for giggles.
Jerry
Old 08 Jun 2012, 07:04 pm
Jerry
FOOK......enough said.....chime back in a bit....
Old 08 Jun 2012, 07:16 pm
jrbsr05pt's Avatar
Don't let your wife see that post. Might take it the wrong way lol jk. Do you have a aftermarket intake?
2005 n/a 5 speed. 177365 miles. spectre cold air intake, white and pink leds under dash and back seats, purple leds in vents, wall with 1 18" subwoofer built behind back seat(soon to be either 16 American bass vfl8's or 4 18's with the wall rebuilt all the way to behind the front seats,cant wait!!!), blue dash lights, pink turn signal indicators. 3D tails and tinted backup lights. Power antenna (that no longer has power ha!) another one gone but wont be forgotten
2003 gt turbo. 130245 miles. autostick, mopar riceplate, 3" o2 housing and downpipe. custom diablo tune (totaled, gone but not forgotten)
2003 dream cruiser. autostick, mopar body kit, mopar bov, cai. s1 injectors. mopar s1 pcm. 3" 02 housing and downpipe installed from last turbo, upper IC hardpipe more on its way soon.......... diablo tuner in the near future.
Old 08 Jun 2012, 11:46 pm
That was the ISSUE!!!
It was the lower mount, under the A/C. The Energy bushing insert strap broke and the constant pressure from the rear insert helped the bolt back off. I cant really tell, but it looks like the main pulley or the A/C pulley rubbed against the frame. All belts look good...
Check the tranny fluid level and topped it off. Then...took it for a romp (with my wife in the passenger seat).
All is back to normal!
No....she never gets on....pheww....
No aftermarket, just a K&N and a mod box...that's all.
04 PT, jerking when accelerating solluna975 Tech & Performance Forum 9 08 Feb 2014 11:45 pm
vibration when first accelerating PurpleMoo41 Turbo Wheels/Suspension/Handling 7 05 Aug 2011 06:24 pm
Grinding/rotating noise coming from left side of car when coming to a stop...help? quietcharm23 Wheels, Tires, Suspension 3 10 Apr 2011 08:43 pm
Brake light comes on when accelerating kmancrx Tech & Performance Forum 11 02 Dec 2009 09:33 pm
More on grinding wazzzzman General PT Cruiser Discussions 1 06 Mar 2009 02:31 pm
