Radiator lifetime - how long did yours last?
Old 09 Jun 2012, 11:55 am
shadetree's Avatar
Default Radiator lifetime - how long did yours last?
Has any consensus emerged as to the average radiator lifetime? I see that the fans seem to last maybe 50-75k, but how about the radiators themselves? I'm changing the fan, torque struts, thermostat, hoses / rubber goods, belt, etc. If the radiator is another high failure item, I'll change it also. For those of you who changed radiators, how many miles did you get?
Many thanks!
Unscheduled maintenance sucks. Planned obsolescence sucks more!
The Best Defense against poor engineering: Reliability Reports at consumerreports.org. Buy the subscription before you buy the car!!
stock '06 PT, NA, 65k. the wife loves it
88 Cherokee, 200k - good fun
06 Accord - love the reliability
Got God?
Old 09 Jun 2012, 12:13 pm
Default Re: Radiator lifetime - how long did yours last?
i have 240k miles on my car, the wrong coolant in it, and the original radiator still works perfectly. even when it's 97, i have the AC cranked, and i am speeding from redlight to redlight.
Old 09 Jun 2012, 12:23 pm
111,000 miles on mine, 2nd fan but OEM radiator. Changed coolant once when it overheated because of the fan.
Old 09 Jun 2012, 12:36 pm
wheelgarage's Avatar
125k and still on the original OEM...
Though the top inlet is starting to get brittle (plastic cap). I will probably replace it before winter just in case. Will most likely get another OEM one, not unless a good inexpensive aluminum one turns up.
2005 Touring Black - Automagic....California Smog Legal
H&R Cup Kit | TSW Sakata 18x8 35ET | Nankang NS-II 235/40/18 | SPC front alignment cam - rear shim | Master Pro Rotors | Master Pro Ceramic F/R pads | Rebuilt Cylinder Head - Safety Valves and Guides | Felpro Head Gasket and upper rebuild kit | Fail-safe 195 degree thermostat | Mopar Waterpump...lol | 3rd radiator fan motor | Gates timing belt kit | WIX filters (oil, transmission) | Mobile 1 5w30 | Mopar ATF4 | Redline Water Wetter | K&N Drop-In | 4th Drive side Axle | Energy Suspension Torque Mounts | 3rd set of Torque Mounts...
Old 09 Jun 2012, 03:19 pm
shadetree's Avatar
OK, so that makes it pretty clear, and it sounds like good fun. I'll try that for a test when I put it back together... :-)
Got God?
Old 09 Jun 2012, 03:54 pm
Just be careful who might be watching while your doing your speeding from light to light.
Old 09 Jun 2012, 07:35 pm
compdr59's Avatar
6 years 95k miles. Started leaking at a seam. Original fan now at 120k.
Original Owner 135k
Old 09 Jun 2012, 08:16 pm
VNT's Avatar
VNT VNT is offline
7 years 100K started leaking at the seam. 03 GT Turbo radiator.
VNT
00 Durango SLT+ 5.9 4x4
02 Grand Cherokee 4.7 4x4
05 PT GT Silver 5 Spd Conv
17 Challenger SRT A8 GoMango
18 JL Wrangler Sahara Punkn
Old 09 Jun 2012, 08:27 pm
767skyking's Avatar
2002, got 128k before neck started chipping away. Replaced with a quality Koyorad.
2003, GT still going strong at 83k
Old 10 Jun 2012, 01:10 pm
'01 w/ 150k. As far as I know it has the original fans and rad, but I bought the car with 100K so it's possible they were replaced.
Tags
radiator
Lifetime Powertrain Warranty ptguy69 General PT Cruiser Discussions 3 09 Mar 2011 10:57 pm
Specifics of Lifetime warranty? ptborder General PT Cruiser Discussions 12 17 Jun 2008 10:05 am
Lifetime oil filter... What do you think? DEEFIEND Tech & Performance Forum 6 15 Feb 2008 01:44 am
It's a long, long drive to Germany... Ed Lim Exterior Accessories Forum 0 05 Jun 2003 03:33 am
