whistle sound/vaccuum leak??
Like Tree6Likes
Old 09 Jun 2012, 11:50 pm
Question whistle sound/vaccuum leak??
Hi There, My name is Shieldwolf and I have a 2001 PT.( non-turbo, limited edition, automatic). i am getting a whistle sound( like a piece of paper ripping or a sm.vacuum leak) ONLY when i accelerate.It sounds like its coming from the EGR valve upper manifold area. There was a recent tune up done. There are no error codes. Could this be coming from the tube? is it something to be highly concerned about? Thanks for a prompt reply!! Peace
Last edited by Shieldwolf; 09 Jun 2012 at 11:58 pm. Reason: i forgot to introduce my self :)
Old 10 Jun 2012, 12:55 am
JenneK's Avatar
Default Re: whistle sound/vaccuum leak??
There are 4 vacuum hoses that I know of.
1. Bottom part of the intake tube on the curve that connects to throttle body.
2. Top of throttle body.
3. On back of plenum. You have to remove the engine cover.
4. Another on back of plenum.
Yes, you should find it and fix it.
Ken posting about his Jenny's car.
01 w/JBA headers, Borla catback, Airaid intake, lowered, purple with shiny wheels.
Old 10 Jun 2012, 11:46 am
well thanks for the reply, Jennek. However what you have told me I already knew. Nothing you stated comes close to actually answering my inquiry.And its only obvious ( & common sense ) to fix the problem when found. But thanks anyway~ have a nice day.
Old 10 Jun 2012, 11:58 am
^^ dickhead
jdpersico likes this.
Old 10 Jun 2012, 01:38 pm
Originally Posted by Harry2011 View Post
^^ dickhead
Now-now, some decorum please! That should be ^^urinary tract appendage/brain container.
Still------X2
Jerry
Old 10 Jun 2012, 02:02 pm
Red face Re: whistle sound/vaccuum leak??
I am so sorry that u folks think I'm a " dickhead "! I was just speaking my mind. OOPS! ( although i really dont know why i am apologizing for stating my opinion )... please forgive my brashness.
Old 10 Jun 2012, 02:57 pm
JenneK's Avatar
Sorry I tried to help.
Didn't really get to finish my post last night. I was typing from my phone at the park.
Anyway, just wanted to add that I doubt it is emanating from the EGR tube itself or rather the EGR operation. The PCM dictates when the EGR will flow exhaust gases into the intake and it usually is when cruising and not accelerating.
However, the bolts may not be fully tightened, or the seal broken, misaligned, missing etc and are allowing air to be sucked in. Did you check that yet?
Shieldwolf likes this.
Old 10 Jun 2012, 03:34 pm
mityqwik's Avatar
Thumbs up Re: whistle sound/vaccuum leak??
on my 06 cruiser i had the same sound and i traced it to a small vac.line next to the brake reservoir,i replaced it over the years a couple of times and hopefully you can see i need to replace it again it's cracked
It takes 8,460 bolts to assemble an automobile,
and one nut to scatter it all over the road
Old 10 Jun 2012, 05:16 pm
Jeenk, TY! again I apologize for my tact, LOL. No, I havent checked the bolts,etc. yet. I had to replace my motor mounts on the right side.And the rubber boots.I also flushed the tranny, gave it new fluid & filter,as well as new tune-up.( all in the last 2 weeks, in my gravel driveway....in the pouring down rain.lol ).When things were all put back together, thats when we noticed the hissing. Its not a continual hiss, its more like a "ch/sh, ch/sh, ch/sh" or kinda like a wire brush dragged across the cement.. and only when i hit the pedal. It does hesitate some at first acceleration,then evens out. I am just now ready to putt around the block or 2 since the R&R.
Old 10 Jun 2012, 05:19 pm
mityqwik~ TY! I will definitely check that out. Is that a row of relays or connectors i see on the right?
Does this sound like a hose leak? Buster716 Tech & Performance Forum 3 14 Nov 2011 10:52 pm
whistle urimashe Tech & Performance Forum 4 27 Feb 2011 12:45 pm
Whistle Sound when warm starting dsmturbo General Turbo Discussions 17 08 May 2010 08:34 pm
Vaccuum Tank?? notadodge Tech & Performance Forum 5 09 Mar 2008 11:27 am
The Whistle... PeTe Turbo Performance 9 10 May 2003 12:25 pm
