timing off! need a shortcut?
Like Tree2Likes
  • 1 Post By wwpptc
  • 1 Post By rsrocket1
Old 10 Jun 2012, 02:49 pm
Default timing off! need a shortcut?
Has anyone ever been able to move the belt 1 tooth on the exhaust sprocket without taking everything back apart?
Old 10 Jun 2012, 03:21 pm
Default Re: timing off! need a shortcut?
no
Jerry
CREWZIN likes this.
Old 10 Jun 2012, 08:18 pm
jdpersico's Avatar
Nope. Unless your belt is so deformed (in that case you should replace it), it's impossible to jump a tooth.
Sorry!
Old 23 May 2019, 04:20 pm
Yes.
Jack up car. Remove wheel. Loosen alternator belt and pull off alt., push it aside.
Undo pencil bracket on top bolt, loosen on bottom, let it hang down.
Reach up and unbolt timing belt tensioner.
Now you have slack to remove belt from cam sprockets. Do so, and you can adjust cam and crank appropriately.
Apply tensioner back onto belt with pry bar.
Observe how belt moves sprockets while pushing into place, and set them accordingly, so that when tension is applied, timer is correct.
Bolt tensioner back into place. Put alternator belt back on.
Attempt to start vehicle.
Old 26 May 2019, 02:29 pm
rsrocket1's Avatar
Hopefully he solved it in the past 7 years
NitroPT likes this.
timing Louly Tech & Performance Forum 3 17 Mar 2012 04:28 pm
Timing morrisbeer General PT Cruiser Discussions 1 06 Apr 2009 07:28 pm
Timing DreamCurZ03 Tech & Performance Forum 3 25 Nov 2008 02:41 pm
